Transport cost?
   / Transport cost? #1
Pops15
Platinum Member
IL
Ford 555 TLB, Caterpillar Motor Grader, Kubota L245, Ford LGT 125, FABTEK aerial platform
What's the going rate for having equipment transported on a lowboy? One piece would have to be moved 200 miles and another 270 miles. Pick up and delivery locations are all in Illinois.
   / Transport cost? #2
Around here a one way trip within city limits is $125 using a Land-all. Your probably going to be charged by the mile. Probably about $2.00/mile.
   / Transport cost? #3
I can't answer your question directly but do offer a recommendation. Try wew.uship.com. I've been using it for 3 years now and have had nothing but great luck.
Works like eBay. Post your commodity that you need transported (with weight and dimensions), post the pick-up and delivery locations and finally, post a time frame that you need it done in. Then sit back and watch the bids roll in. Companies will bid on your move. Their bids are available for other shippers /carriers to see and then it starts getting competitive.
I've had terrific luck but make sure to read the fine print with each shipper, check insurance coverage and just like eBay, review their feedback.
Good luck!
   / Transport cost?
I was quoted $800 for a 200 mile haul. Basically $2 a mile loaded, and $2 a mile unloaded for his drive home. Didn't know if that was reasonable or if I should look for someone else.
   / Transport cost? #5
Thats about right. $5 per load mile with a minimum and a load fee is the norm around here.
Chris
   / Transport cost? #7
Wow, I'm in the wrong business!
   / Transport cost? #8
You obviously don't buy diesel fuel, large vehicle insurance, local/state and federal permits! Fill out a log book, are told when you can drive, must stop to get weighed, prohibited to use certain roads!
   / Transport cost? #9
A rule of thumb we always used was roughly the cost of a gallon of fuel per loaded mile. So if diesel was $3.99/gal it would be $4 a loaded mile. Sounds about right.
   / Transport cost?
Thanks for the replies.
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
Enclosed 16ft S/A Cargo Trailer (A51694)
Enclosed 16ft S/A...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
8ft Forklift Safety Basket Attachment (A51691)
8ft Forklift...
