Transmission/ steering Pump low pressure warning lamp
   / Transmission/ steering Pump low pressure warning lamp #11
I thought of that as soon as I posted my question. The trans/steering pressure switch was a piece of cake. The 4wd pressure switch was a tough to reach. The toughest part of the job was putting the tire back on (they are filled). My tractor is back up and running. Thank you for all of your help.
Mine is doing the same thing, at isle light is on with the steering wheel and when I turn wheel it shuts off for a bit, or if I rev up the tractor then it stays off until I lower throttle back down to a idle. I replaced some switches that the dealer told me to replace cause light was on when I was running tractor and would **** off as soon as I put in neutral, now that I replaced them, it does it at a idle. Please help driving me crazy and dealer is no help. Case mxu135.
LOT: (2) Piece Mac Tools TRCH 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper Tool Box (A59076)
LOT: (2) Piece Mac...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
2016 Ford F-350 4x4 Crew Cab Utility Flatbed Truck (A55973)
2016 Ford F-350...
