transmission problems
/ transmission problems #1
Johnagain
Central Florida
JD 4310
I just got my JD 4310 E PowerReverser back from the dealer to have some warranty work done and when I went to load it on the trailer I found that I have no 1st gear. I drove it around the lot and found that in mid range that 1st gear is the same speed as 4th, and 2nd is the same as 3rd. I can now change between 1st & 4th and back again without using the clutch it is also the same way between 2nd & 3rd and back again. The actual ground speeds appear to be 3rd and 4th gears with 1&4 being slower that 2&3. I have the tractor at home now but will take it back after I'm finished with this job. I have not put it in the other ranges yet to see if this remains the same. They didn't open the gear box so they have no idea what has caused this. The repairs they did are:
1 repaired tilt steering
2 tighten rockshaft so 3pt wouldn't drop
3 replaced leaking steering cylinder
4 adjusted neutral safety switch linkage
5 replaced battery tray after new style battery leaked.
The only thing i think that could possible have anything to is the neutral safety linkage but they are sure this won't cause this problem.
The mechanic is checking with deere to see if this problem has come about in the past. Nothing makes sense to me. Any suggestions will be helpful.
Thanks John
/ transmission problems #2
How much did the steering cylinder cost around $1,100 ?
It was done under warranty so I have no idea how much it cost.
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 Chevrolet...
New/Unused Landhonor Quick Attach Auger (A61166)
New/Unused...
2010 Honda Accord Sedan (A61569)
2010 Honda Accord...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59909)
2016 FREIGHTLINER...
