Transmission problems Massey Ferguson 5465 series 2004
   / Transmission problems Massey Ferguson 5465 series 2004 #1
Ignacioap
Peru
Massey Feguson 5464
Previous Greetings .
I have problems with agricultural tractor Massey Ferguson 5465 2004 Series , with the following problems:
- Changing Caracol range of rabbit does not work.
- The rear hydraulics not not work.
- The inverter forward command does not work.
Thank advance me some technical assistance how to solve this problem.
Best regards Ignacio
   / Transmission problems Massey Ferguson 5465 series 2004 #2
Welcome to the forum, Ignacio. :)
I'm going to move your thread on over to our Massey section to see if we can find you some answers.
   / Transmission problems Massey Ferguson 5465 series 2004 #3
G'day Ignacio and :welcome: I'm guessing the three are related problems if you can work out the rear hyd not working then you might sort your other issues out.
Sorry but I don't have any literature on your model to run you through the testing procedure so hopefully someone will chime in soo with some help
Jon
   / Transmission problems Massey Ferguson 5465 series 2004 #4
Hello Ignacio, more details please.
1) are you using a "dyna 4" or some other gearbox?
2) is caracol spanish for snail?
3)what are the tractor hours?
4) "inverter forward command" ??? does this refer to the forward/reverse lever on the left hand of the steering wheel or something else? Was the failure a sudden "stopped working" or did the problem start intermittant and gradually get worse until it no longer works?
5) detail symptoms of rear hydraulic failure. ie 3 point link, rear external hydraulic outlets (scv) sudden stop/ slowly get worse until stopped working.
6) what are the duties of this tractor? loader, tillage?
Hi, redman135
1. The gearbox is DYNA 4
2. Yes, snail.
3. 5000 hours approx.
4. Yes, I refer to the forward lever on the left hand, the failure was 都topped working
5. The hydraulic failure was sudden stop.
6. The duties of tractor loader and tillage.
   / Transmission problems Massey Ferguson 5465 series 2004 #6
Hello Ignacio.
On the dyna 4 models I ran into this problem once before on a loader tractor with similar hours as yours. The forward or reverse sensor fails due to wear. The solution is to replace the sensor.
On the hydraulic problem , I unable to help you. Hydraulics are beyond my skill.
I make an alternator repair and now the machine is not going forward and one backward
2019 Ram 5500 Dump Bed, VIN # 3C7WRNFL2KG599631 (A51572)
2019 Ram 5500 Dump...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
1999 International 4700 Dump Truck, VIN # 1HTSCAAN3XH660516 (A51572)
1999 International...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
