Transmission problems Massey Ferguson 5465 series 2004
   / Transmission problems Massey Ferguson 5465 series 2004 #1
Ignacioap
Peru
Massey Feguson 5464
Previous Greetings .
I have problems with agricultural tractor Massey Ferguson 5465 2004 Series , with the following problems:
- Changing Caracol range of rabbit does not work.
- The rear hydraulics not not work.
- The inverter forward command does not work.
Thank advance me some technical assistance how to solve this problem.
Best regards Ignacio
   / Transmission problems Massey Ferguson 5465 series 2004 #2
Welcome to the forum, Ignacio. :)
I'm going to move your thread on over to our Massey section to see if we can find you some answers.
   / Transmission problems Massey Ferguson 5465 series 2004 #3
G'day Ignacio and :welcome: I'm guessing the three are related problems if you can work out the rear hyd not working then you might sort your other issues out.
Sorry but I don't have any literature on your model to run you through the testing procedure so hopefully someone will chime in soo with some help
Jon
   / Transmission problems Massey Ferguson 5465 series 2004 #4
Hello Ignacio, more details please.
1) are you using a "dyna 4" or some other gearbox?
2) is caracol spanish for snail?
3)what are the tractor hours?
4) "inverter forward command" ??? does this refer to the forward/reverse lever on the left hand of the steering wheel or something else? Was the failure a sudden "stopped working" or did the problem start intermittant and gradually get worse until it no longer works?
5) detail symptoms of rear hydraulic failure. ie 3 point link, rear external hydraulic outlets (scv) sudden stop/ slowly get worse until stopped working.
6) what are the duties of this tractor? loader, tillage?
Hi, redman135
1. The gearbox is DYNA 4
2. Yes, snail.
3. 5000 hours approx.
4. Yes, I refer to the forward lever on the left hand, the failure was 都topped working
5. The hydraulic failure was sudden stop.
6. The duties of tractor loader and tillage.
   / Transmission problems Massey Ferguson 5465 series 2004 #6
Hello Ignacio.
On the dyna 4 models I ran into this problem once before on a loader tractor with similar hours as yours. The forward or reverse sensor fails due to wear. The solution is to replace the sensor.
On the hydraulic problem , I unable to help you. Hydraulics are beyond my skill.
I make an alternator repair and now the machine is not going forward and one backward
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
Guard Rail Joints (A51692)
Guard Rail Joints...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
