transmission problem
/ transmission problem #1
roger3
bassano ab
case 580superk
I can only shift from 1st to 2nd. Cannot get 3rd or 4th gear in case 580 super k ?
/ transmission problem #2
Did this just start? Is the Case 580 new to you? Have there been any issues with the way the clutch has been acting? What condition and level is the transmission fluid?
/ transmission problem #3
I don't know much about these tractors but if there are no unusual noises coming from the transmission then I would suspect the interlock mechanism in the shift cover. Most manual transmissions have something like this so that you cannot shift into two gears at the same time.
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
Case-IH 370 Steiger (A57148)
Case-IH 370...
(INOP) JOHN DEERE 450CE CRAWLER DOZER (A59823)
(INOP) JOHN DEERE...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
gps trailers (A56859)
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
