Transmission problem on LT180
/ Transmission problem on LT180 #1
Mike Buckley
Cub Cadet Sc 2400
I need some advice. I have a JDLT180 lawn tractor with a Tuff Torq automatic hydrostatic transmission. Recently while taking off the rear tire and putting a new one on I had to move it and I pulled out the free-wheeling lever. I started the engine and let it run for a while due to the cold---forgetting to push the free-wheeling lever back in. Now, my tractor won't move. Of course then I checked the manual and saw the big warning about not starting the tractor with the lever pulled out.
Is my tranny cooked or is it reparable? Thanks for any advice.
I should add that when I have the free wheel lever pushed all the way in I can still push the tractor by hand. So it's like the lever isn't engaging inside the transaxle.
/ Transmission problem on LT180 #2
Usually when you push the brake in it re engages the free wheel lever. So I would push the brake down as far as you can with out break or bending anything then try it again
/ Transmission problem on LT180 #3
Are you sure the axel key is in there? They can sometimes fall out while replacing the wheel on the axel and it will act the same as you describe.
Thanks for both responses! I'll check both after work today.
Thanks BATTY54. I'm embarrassed but grateful. I think I left the axle keys in the rims when new tires were put on the rims at the shop and I don't have them. Stupid!!! A few bucks for the keys is way better than a transmission repair, though. At least some stupid mistakes are cheap and easy to fix!
/ Transmission problem on LT180 #6
Glad to help at least it is a cheap easy fix
2009 FORD CROWN VICTORIA CAR (A66091)
2009 FORD CROWN...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
PORTA POTTY (A68842)
7002SFL (A61572)
7002SFL (A61572)
2021 Deere 331G (A64911)
2021 Deere 331G...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
