Mowing Transmission Overheats
   / Transmission Overheats #1
gadoves1
ochlocknee ga
jd 5103
I have a 08 JD 5103 tractor with approx 1650 hrs on it. I primarily use it for mowing my 25
acre pecan orchard. The problem I am having now is the transmission gets so hot that it nearly burns my hand to touch
any part of the transmission housing. I replaced the hyd fluid filter this morning and that did not help at all. Has anyone out there had a similar problem? Thks for your response. BTW, I am not using JD Hy Gard fluid but generic from from Tractor Supply.
   / Transmission Overheats #2
First - are you sure the transmission is overheating now and ran at a cooler temperature before? It doesn't need to be extremely hot to be too hot for touch. I use an infrared temperature gun to periodically check my tractors. Super accuracy is not important - I have cheap ones from Harbor Freight in each of my tractors.
Second - your tractor has an open center hydraulic system. If for some reason a valve is stuck or something similar happens, all the oil will be pumped over the 2800 psi relief and it will overheat quickly.
Third - the 3 point system - if the feedback is out of adjustment, the hydraulics can still be getting a signal to raise when the arms are at the top. Check to make sure this isn't causing the hydraulic system to run continuously at relief.
Tractor Data indicates you have 2 hydraulic pumps - a 6.8 gpm steering pump and a 9.5 gpm pump for other hydraulic functions. Need to check both systems.
   / Transmission Overheats #3
I forget the actual number, but I believe 120 deg f is close to where an object is too hot to maintain contact with. A transmission is definitely going to be too hot to touch when up to temp. My past 2 tractors (hst) would get up to 190-200 deg f when worked.
   / Transmission Overheats #4
I would agree with using an infrared thermometer and check the hydraulic functions. I would also check the hydraulic oil cooler to make sure it is clean too on a regular basis.
   / Transmission Overheats #5
You changed the filter but did you clean the screen in the differential? It's right next to the PTO shaft. You'll have to drain the hydraulic fluid. About 10 gallons.
Ditch Witch 350Sx Ride On Vibratory Plow (A50322)
Ditch Witch 350Sx...
2005 Hummer H2 4WD SUV (A50324)
2005 Hummer H2 4WD...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
