Transmission Oil UTB / Long 530DTC
   / Transmission Oil UTB / Long 530DTC #1
dementinator
UTB / Long 530DTC
Hi, new here, I have a UTB (Universal) 530DTC tractor also known as a Long in the US, a Fiat derivative I believe, I would like to top up the trans oil as is low due to a leak, does anyone know what type of oil is used and where the filler is, the dipstick is in front of the seat by the gear shift.
Many thanks
   / Transmission Oil UTB / Long 530DTC #2
The filler hole is under and to right of sear as youre sitting on it.crescent wrench,remove cap,top off watching dipstick with engine off.
Many thanks for that, will take a look later..
One other question, the dipstick has multiple markings on it, the highest one on one side is marked DT not sure if thats the level I need.
Once again many many thanks...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
