transmission oil, rubber fuel lines
   / transmission oil, rubber fuel lines #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I am working on a project and plan on mounting an external cooler for a gear box that uses transmission fluid for lubrication. I was going to use some left over 3/8 rubber fuel supply hose laying around to plumb the gear box to the cooler but was told not to b/c trans fluid will eat away at the fuel line hose, causing pieces of rubber to get into my gear box. Is this true? I've never heard of this before. The guy recommended hydraulic lines, but that stuff can get pricey.
   / transmission oil, rubber fuel lines #2
Deerefan,
You should use hose that is rated for oils. You can find it at any auto parts store...ask for trans/oil cooler hose. It isn't much more expensive than fuel line. The problem with fuel line is that it may not be rated to take the pressure you are going to push through it.
Jeff
   / transmission oil, rubber fuel lines #3
some of the newer fuel line is rated for gas, oil and diesel, i got some from napa a while back that was listed as such. regular gasoline line will get kinda puffy over time when used on oil or diesel fuel lines. now thats not to say that you shouldnt use tranny line for your application since it may be rated for a higher pressure. i usualy use gates weatherhead line for power steering and tranny lines, thats what we have at work for that use
I see....thanks for the input.
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55218)
2017 Ford F550...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55218)
Kubota BX2680...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
