Transmission Oil Light Won't Go Off NH TN75SA
   / Transmission Oil Light Won't Go Off NH TN75SA #1
EmpireTractor2012
NY
New Holland TN75
I have a New Holland TN75SA tractor where the transmission oil light came on. We have changed the oil pressure switch and the light hasn't gone off. I've been told that the wires have been checked for any pinching as well and nothing was wrong with them. We aren't sure what to check next. The customer, as well as ourselves, would appreciate the help.
   / Transmission Oil Light Won't Go Off NH TN75SA #2
If you have a shop, did you think to pressure test????
We have already done a pressure test as well.
   / Transmission Oil Light Won't Go Off NH TN75SA #4
Did you change the correct pressure switch? There are two of the same switch, one for the 4WD and one for the transmission. Trans switch is oriented parallel with the rear axle, 4WD switch is perpendicular to it.
   / Transmission Oil Light Won't Go Off NH TN75SA #5
I have seen new switches that were bad.
If it is set up that the switch is a normally closed switch and pressure opens it try disconnecting the switch to see if the light goes out. It it does it is probably the switch if you know the pressure is correct (as Rick stated it could be the wrong one). If not either the panel is bad or you have a short feeding it somewehere.
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
NEWTON CROUCH 1-04-7612 FERTLIZER SPREADER (A51247)
NEWTON CROUCH...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
