Transmission Oil Light Won't Go Off NH TN75SA
   / Transmission Oil Light Won't Go Off NH TN75SA #1
EmpireTractor2012
NY
New Holland TN75
I have a New Holland TN75SA tractor where the transmission oil light came on. We have changed the oil pressure switch and the light hasn't gone off. I've been told that the wires have been checked for any pinching as well and nothing was wrong with them. We aren't sure what to check next. The customer, as well as ourselves, would appreciate the help.
   / Transmission Oil Light Won't Go Off NH TN75SA #2
If you have a shop, did you think to pressure test????
We have already done a pressure test as well.
   / Transmission Oil Light Won't Go Off NH TN75SA #4
Did you change the correct pressure switch? There are two of the same switch, one for the 4WD and one for the transmission. Trans switch is oriented parallel with the rear axle, 4WD switch is perpendicular to it.
   / Transmission Oil Light Won't Go Off NH TN75SA #5
I have seen new switches that were bad.
If it is set up that the switch is a normally closed switch and pressure opens it try disconnecting the switch to see if the light goes out. It it does it is probably the switch if you know the pressure is correct (as Rick stated it could be the wrong one). If not either the panel is bad or you have a short feeding it somewehere.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
More info coming soon! (A50323)
More info coming...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
