Hi Folks,
I have a '95 B2100 that's developed a very small oil leak from the joint at the hydraulic pipe and oil filter mount. It looks like it's from the pipe that returns oil to the transmission as it leaves the filter mount. This looks like a simple fix and I have the two O rings which serve as the seal at the end of the pipe on the way.
Before I tear into things this weekend, I wanted to run this by you guys and see if you have any advice from past experience or replacement.
Thanks in advance.
K
Thanks in advance.
K
