Transmission/Hydraulic oil in F40
   / Transmission/Hydraulic oil in F40 #1
F40 man
WI
Fergusen F40
Hi All
I am re-doing the transmission in my F40 and was wondering what oil to put in it. The manual calls for a mineral oil 90 wieght, and I checked back in some forums here, but am confused. Is a GL1 90 what I want to use or GL 2,3,4,5????? Thanks Mike
   / Transmission/Hydraulic oil in F40 #2
GL1 90 is a gear oil you need to find a gear with MF 1103 spec.
Thanks cornshucker, Can yu tell me where to find that. I found GL1 oil at NAPA but dont know if it has the Massey 1103 spec.
Thanks again Mike
   / Transmission/Hydraulic oil in F40 #4
Thanks again Mike
GL1 SAE 90 oil is what the OEM speced for your F40. Most of the Universal Tractor Fluids (UTF) are also compatible. NAPA carries GL1 for sure as you noted. AGCO dealers whould carry MF 1103 oils IF they are still available but most of the newer speced oils are back compatible to the older tractors.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 Ford Expedition (A51694)
2015 Ford...
UNUSED JCT HD HYD BACKHOE ARM (A51248)
UNUSED JCT HD HYD...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
1839 (A51248)
1839 (A51248)
