Transmission/hydraulic oil heater
   / Transmission/hydraulic oil heater #1
JCByrd24
Midcoast Maine
John Deere 2320
Hi all, wanted to share a piece of great news I recently discovered for fellow cold weather operators. My 186D has always been slow to warm up (hydraulic fluid) when it's cold out (below 35 degrees F or so). The pump whines a little and the loader is slow for a while even after the proper warm up. I was hoping to make this better recently with a fluid/filter change and screen cleaning, but it actually got worse. The fluid is proper grade, but apparently just a little thicker in colder weather than the previous. In my opinion the filter being on the suction side (in addition to the screen) is design flaw. This should have been in return, but oh well. This prompted me to look once again for the yanmar transmission heater referenced in the owners manual. No luck finding the PN online this time around either (and I guessed the dealer would be no go or $$$$). I decided first to take a close look on the tractor in the area the manual shows. Low and behold, the square headed plug just forward of the left rear axle appears to be a simple pipe plug, not some fancy hydraulic fitting. I measured it and it jived with a 1/2" NPT (almost 7/8" diameter), so after a little googling I ordered up one of these:
Kat's 11423 400 Watt 1/2" NPT Frost Plug Heater : Amazon.com : Automotive
I figured for $24 I couldn't go wrong, and I didn't.
I installed today without even draining the fluid, just some quick hands (I could tell after a few turns of the factory plug it was very likely NPT), and tested it out. Even with it plugged in for just 10 minutes or so, the tractor was noticeable happier on start up. I'm a happy guy.
   / Transmission/hydraulic oil heater #2
Was starting the tractor easier too? Any chance you have a picture or the schematic from the manual of where this installed? I gave up on removing the engine block plug so I am very interested in this.
   / Transmission/hydraulic oil heater #3
No I don't think this will impact the starting, it's quite a distance from the engine. I already have the block/coolant heater as well, it came with the tractor. It works wonders for starting in cold temps. I would try some penetrating oil/heat and a bigger wrench, in my experience the block heater is a must, thermostart alone doesn't cut it. I will get pics of the manual pages soon.
(APPROX 34) 1 1/2" X 10" X 38" CHANNEL IRON (A51247)
(APPROX 34) 1 1/2"...
PAIR OF SINGLE AXLE TRAILER FENDERS (A51247)
PAIR OF SINGLE...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
New 2025 NextGen 7x16 Utility Trailer (A51573)
New 2025 NextGen...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
