Transmission gets stuck in 1st
/ Transmission gets stuck in 1st #1
COASTBUSTER
SHIRLEY,NY
4000 hd industrial 1964
I have a ford 4000 hd industrial with a sherman tranny. It seems that whenever the tractor gets twisted,for instance, one wheel going in a hole, the tranny gets stuck in 1st gear. It may happen in other gears also but so far,whenever it has happened I have been in 1st gear. I can shift into reverse but the engine will just die because two gears are opposing each other. to fix it I have to remove the shifter plate and move the fork back into neutral manually. when the tractor is on flat ground it seems to work fine. p.s. it is a four speed. Any incite would be appreciated. Dan :confused:
/ Transmission gets stuck in 1st #2
guess it's time to build up/repalce that shifter nub and check that shift guide pattern.. might as well check detends and forks for being loose.. etc.
soundguy
HLA Attachments Loader Forks (A64119)
HLA Attachments...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
AGRI-CRAFT STAINLESS STEEL FERTILIZER TENDER (A63291)
AGRI-CRAFT...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
