Transmission fluid on sale at Tractor Supply
   / Transmission fluid on sale at Tractor Supply #1
ulflyer
lexington nc
CK 30H
Stopped in today to see what they had and the 5 gal buckeks were on sale for $32+. Its labled Travellers Premium USe Tractor Trans/Hyro Fluid. I assume this is as good or better than Walmart or Napa?
Of interest to me is that they also have the same stuff in 2 gal containers for $17 which for me would be much easier to handle.
Their 80-90W gear lube is reg priced at $4 quart.(GL-5). I may use that for the front axle of my CK-30.
   / Transmission fluid on sale at Tractor Supply #2
I used both with no problem. I put a hand pump on top of the five gallon pail and pumped it into the tractor rather than lifting (and spilling) the 5 gal bucket. My CK20Hst used more than 5 gallons, maybe 7, you will know when you drain the system, have enough buckets ready.
   / Transmission fluid on sale at Tractor Supply #3
Quite often, it is all the same manufacturer, Warren Distributing.
As for the gear lube, for just a few bucks more, you can put synthetic 75w-90 in your axle and enjoy the superior benefits. my $.02 Bought a quart from Family Farm yesterday for $6. You guessed it, blended by Warren.
Stopped by NAPA and counterman had Valvoline for about $6 (non-syn) and NAPA brand which he said was also Valvoline for $2.79. Bought his brand.
48" JOB BOX (A51248)
2005 GMC 8500 (A50123)
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
