Oil & Fuel Transmission filter removal
   / Transmission filter removal #1
JAMES BOUCHER
Tyler Texas
1951 Ford 8N and 2008 Kubota L3240 with Loader
I have a Kubota L3240 and I'm trying to remove Trans filter. I've used two different filter wrwnches and can't break the filter loose to put on a new one for my 50 hour first filter change. I have changed the oil filter, oil and Hydraulics filter but can't get the Trans filter to break loose. Any ideas would help. I'm afraid I will puncture the filter can then I'll be in worse shape.
   / Transmission filter removal #2
Which filter is it the heavy rounded one? I had to use a strap wrench on mine and I have read where a few guys used a pipe wrench to get it to come loose.
   / Transmission filter removal #3
I used a channel lock for mine..twisted to pieces but it's not like I was planning on reusing it :p...
It's the heavy rounded one on the transmission under the step. I did not want to tear it up getting it off. It's 23 miles to the Kubota dealer if I screw it UP! I'll look for a strap wrench. The wrench I was using is like a pair of water pump pliers. Adjustable for different size filrers. It also slips when I get down on it.
   / Transmission filter removal #5
Yea that the high pressure filter and it is pretty thick, not like a car oil filter. I would use a strap wrench. I would have a new filter on hand before I started.
Glad to know it's the heavy one. I have torn up car filters before and removed them in pieces. I guess it is a strap wrench and a cheater pipe. I have replacement filter on the bench. When I replaced the Hydr. filter I lost about 1/2 gal of Super trans oil. I guess I'll lose about the same amount when I replace the Tranny filter. I better get another gal. of fluid before I start. That will be Monday and another $15.
   / Transmission filter removal #7
I think this is the one with the magnet in it (sets on the top) so make sure and clean the magnet and put it on the new filter.
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
Deere 35G (A53317)
Deere 35G (A53317)
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
2003 Big Tex 10PI...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
