Transmission filter on BX2370
   / Transmission filter on BX2370 #1
vettman
Replaced the trans filter at 50 hours, as specified in the owner's manual. What a PIA to remove this filter. I used a pair of wide opening channel lock pliers to remove the old filter. Buggered it up pretty badly, but since it's a throwaway, not a problem. I was unable to get any of my bottom gripping tools into the narrow space available. Is there a better way to do this?
thanks
   / Transmission filter on BX2370 #2
thanks
Next time will be a breeze. New machine's filters are painted on.
   / Transmission filter on BX2370 #3
thanks
I use a pair of the $8.11 Oil Filter Pliers. Always wanted one of the $58.74 Chain Link removers though. Maybe someday I will have a weak moment and pay that for something used once a year.
tight space oil filter wrench - Google Search
Thanks, Sandy and Gator. As pricey as Kubota filters are, they should weld a hex nut on the bottom, a la K&N. Hope this one will release easier than the original, when it comes time to replace. I値l pick up a pair of the oil filter pliers the next time I知 in WM.
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
JOHN DEERE LOT NUMBER 167 (A53084)
JOHN DEERE LOT...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
