Transmission filter on BX2370
   / Transmission filter on BX2370 #1
vettman
Replaced the trans filter at 50 hours, as specified in the owner's manual. What a PIA to remove this filter. I used a pair of wide opening channel lock pliers to remove the old filter. Buggered it up pretty badly, but since it's a throwaway, not a problem. I was unable to get any of my bottom gripping tools into the narrow space available. Is there a better way to do this?
thanks
   / Transmission filter on BX2370 #2
thanks
Next time will be a breeze. New machine's filters are painted on.
   / Transmission filter on BX2370 #3
thanks
I use a pair of the $8.11 Oil Filter Pliers. Always wanted one of the $58.74 Chain Link removers though. Maybe someday I will have a weak moment and pay that for something used once a year.
tight space oil filter wrench - Google Search
Thanks, Sandy and Gator. As pricey as Kubota filters are, they should weld a hex nut on the bottom, a la K&N. Hope this one will release easier than the original, when it comes time to replace. I値l pick up a pair of the oil filter pliers the next time I知 in WM.
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
LOT LOCATIONS (A52577)
