Transmission Dump Valve? Ford 555B
   / Transmission Dump Valve? Ford 555B #1
Johnny Glenn
88 Ford 555B
Thanks for looking in - I recently purchased an 88 Ford 555B and the Trans Dump Valve is not working. I took off the base plate and see the contact arm mechanism is bent out of place / broken but I also don't see any wiring. Should there be wiring??....and where would it go? Thanks.
   / Transmission Dump Valve? Ford 555B #2
Power should go from the fuse panel, to the micro switch under the floor board, then down to the dump solenoid on the LH side of the trans.
   / Transmission Dump Valve? Ford 555B #3
Looks like this
Thanks - I had a strong feeling they weren't using wireless technology in 88!! Part #28 has been worn out - I don't even see where a wire went - I'll order a new one right away. Thanks for the diagram - what does #38 correspond to and I cant quite tell which fuse it should go to? Thanks again!
   / Transmission Dump Valve? Ford 555B #5
Fuse placement would constantly change on those machines. The repair manuals and op manuals never agreed. A lot of times, I'll run a new wire from the key switch, through an inline fuse, then to the two disconnect switches.
   / Transmission Dump Valve? Ford 555B #6
Where did you find the above scematic? My local new holland dealer cannot find the dump valve solinoid in his system. thanks...
2019 Chevrolet Express 2500 Cargo Van (A51692)
2019 Chevrolet...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A53426)
2014 INTERNATIONAL...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2018 Great Dane Freedom LT 102"x48' Flatbed Trailer (A50123)
2018 Great Dane...
