Transmission drain plug size Kubota b2920
   / Transmission drain plug size Kubota b2920 #1
Tractorrr
TN
kubota bx 2370-1
Does anyone know the size of the transmission drain plug on the B2920? It came off while mowing along with all the hydraulic fluid and now the tractor will not move. I think I will have to retap and larger drain plug. I had a thread about this a while ago and thought I had fixed it with a new drain bolt but obviously that didn't work. Any help would be much appreciated. Will probably try to call Kubota tomorrow but if anyone knows the size I thought I would ask.
   / Transmission drain plug size Kubota b2920 #2
If the B2920 is the same as my B2620, there are two plugs that are 12mm.
   / Transmission drain plug size Kubota b2920 #3
You must have done something wrong to strip the threads. Kubota builds the best!
Yeah I may have overtightened the bolt. When I was taking the bolt off to change the hydraulic fluid I may have started by turning the wrong way rather than loosening it to take it off. Guess I wasn't used to taking off bolts laying on my back under tractor and got the loosening and tightening direction confused. Either that or I could blame it on the previous owner but either way it's got to be fixed.
Was able to get the M12 1.25 bolt to catch enough threads and filled it back up with hydraulic fluid so I could at least get it back to it's home.
Thanks for the bolt size Oldballs!
2011 TIGERCAT 234 KNUCKLE BOOM LOADER (A51242)
2011 TIGERCAT 234...
2006 Dodge Ram 3500 Pickup (RUNS)(TITLE) (A50774)
2006 Dodge Ram...
Quick Attach Pallet Forks (A47384)
Quick Attach...
PORTABLE METAL FUEL TANK (A51243)
PORTABLE METAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Cat DPL40 Forklift (NOT RUNNING) (A50774)
Cat DPL40 Forklift...
