transmission belt and more
   / transmission belt and more #1
2horsewheel
frequently frozen, MN
wheel horse
Hi,
today my 1042 stopped moving. I stopped to get a belt while doing other stuff, but it's a bit more.
The belt came off of the transmission pulley and wrecked the fan. Then I checked the front part and it didn't look like fun.
So, I'm looking for info.
On the back, I think that I can clamp the hub on top of the pulley with a pliers to take off the old fan. Not sure , but I think that I'd have to grab the pulley itself to tighten it down again with the new fan installed.
In the front, it would seem that I have to remove the PTO drive. It's a fairly simple part - not electric. It's a shaft with a bolt going through it and 2 pulleys for the belts. But the tranny pulley is has shields around it and I don't think that I could get a belt in without doing something. (I did see a video that suggested loosening the motor mounts, but it was a different setup. ). I'm a little worried because it looks like it goes into an oil seal -- which makes sense I guess.
Appreciate any suggestions -- especially if you've actually done this !
Thanks,
hj
   / transmission belt and more #2
Yes. Either remove the pulley or if you can't, remove the 2 nuts to drop the steering rods and remove the 4 engine bolts. Then you can lift the engine with a bar to get the belt around the pulley. Is your fan held with a clip or a bolt. If a bolt, use the belt to grip the pulley.
Thanks for that, but I caved and took it in. Possibly could have done it, but I didn't want it to drag on while my grass was growing by the fiit :).
Mechanic said that the pto pulleys frequently sieze onto the engine, and that they have a special puller -- and of course, a lift.
But, I appreciate the info. I like to do my own stuff and I always like finding out about how to do things.
hj
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51242)
SET OF SKID STEER...
