Transmision Whin on B3030
   / Transmision Whin on B3030 #1
mazurrj
Bronze Member
SW PA
B3030,Big Boss4x6 ATV
I've noticed since last fall i hear a whine or squeal from the transmition area when moving. If i stop the whinning stops. This is only for the 1st 5-10 minis then no noise.
Is this something i should be concerned about or any ideas what its from or what i can check?
It has 320 hours and use SUDT.
   / Transmision Whin on B3030 #2
Sounds like it goes away once the transmission is warmed up. Some whining when cold is normal. Was the SUDT changed at 300 hrs.?
yes , i think it started shortly after i changed it. I changed all the filters and been checking the level. I'll have to try it in differnet gears. I think i notice it in High mostly.
   / Transmision Whin on B3030 #4
I have the same problem with my B2630 in another post someone suggested I had a small air leak. Possibly in one of the filter gaskets. I have not changed the filters on mine but it may be worth trying if the whine is bad enough.
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
Ford F-450 Utility Truck (A52128)
Ford F-450 Utility...
2019 INTERNATIONAL 4300 26FT CDL REQUIRED BOX TRUCK (A51222)
2019 INTERNATIONAL...
MAHINDRA EMAX 225 TRACTOR (A51243)
MAHINDRA EMAX 225...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
