cmyoung2
Platinum Member
- Joined
- Jun 21, 2010
- Messages
- 552
- Location
- North west NC mountains
- Tractor
- BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
Not sure if this is the correct place, but. 1999 F250 4x4 V10 5speed. Would like to put a parking brake on the driveline just behind the transfer case. Rotor bolted between the output flange and the driveshaft. I see two options for the caliper, either a bracket off the transfer case or mounted on a frame crossmember. Crossmember will be easy, but I'm not sure how much flex there is between the frame and the end of the transfer case. Bracket off the transfer case will be a challenge. Any ideas??
I'm looking for a parking brake that will actually work, the original inside the rotor brake has never worked, will not spend any more $ on trying to get them to hold. For now the parking brake is low range 1st gear, engine off. 1st gear 2 wheel dr on a hill will not hold, and all we have is hills.
