Trans. hydraulic fluid confusion
   / Trans. hydraulic fluid confusion #1
Jael
Molalla, oregon
International 284
Hey everyone, i have a 70's International 284 that i picked up and want to get the fluids changed. I found the fill plug for what i believe is the hydraulic fluid on the top of the PTO. It looks like from what i was able to find on forums that maybe the trans fluid and hydraulic fluid are the same? Is this accurate and if so what weight/type of oil should i use? and if not where might the trans fill plug be and what type of fluid would i use for trans?
Thanks for any help.
   / Trans. hydraulic fluid confusion #2
Most tractors use the transmission housing as the hydraulic sump. So ya, it's the same fluid.
For anything over 20-30 years old any modern generic hydraulic/transmission fluid is gonna do a better job than what was available back then.
Perfect. Thanks for the info.
   / Trans. hydraulic fluid confusion #4
:welcome:
To TBN Jael. Glad that you joined and as you can see, you can get any question answered.
Do you have a Work Shop Manual (WSM) for your tractor? It can answer a lot of questions and give you a wealth of knowledge about your tractor?
2005 Sterling Acterra Tender Truck (A55301)
2005 Sterling...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2017 ISUZU NPR 16FT BOX TRUCK (A54607)
2017 ISUZU NPR...
40ft 10-Door Shipping Container (A52377)
40ft 10-Door...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
