Trans. hydraulic fluid confusion
   / Trans. hydraulic fluid confusion #1
Jael
Molalla, oregon
International 284
Hey everyone, i have a 70's International 284 that i picked up and want to get the fluids changed. I found the fill plug for what i believe is the hydraulic fluid on the top of the PTO. It looks like from what i was able to find on forums that maybe the trans fluid and hydraulic fluid are the same? Is this accurate and if so what weight/type of oil should i use? and if not where might the trans fill plug be and what type of fluid would i use for trans?
Thanks for any help.
   / Trans. hydraulic fluid confusion #2
Most tractors use the transmission housing as the hydraulic sump. So ya, it's the same fluid.
For anything over 20-30 years old any modern generic hydraulic/transmission fluid is gonna do a better job than what was available back then.
Perfect. Thanks for the info.
   / Trans. hydraulic fluid confusion #4
:welcome:
To TBN Jael. Glad that you joined and as you can see, you can get any question answered.
Do you have a Work Shop Manual (WSM) for your tractor? It can answer a lot of questions and give you a wealth of knowledge about your tractor?
2017 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2017 VOLVO VNL...
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
