trans hard to shift
/ trans hard to shift #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
I have a jd 1070 with about 2500 hours. It runs great but after I run my 90" finish mower for about an hour it gets a little tough to shift. When I mow I really only use 2nd gear and reverse in middle range. It almost feels like the clutch isn't fully disengaging. The only thing that I have checked is the free-play and it is now adjusted to spec (5/8"). When I pull my 7 foot scraper blade around I don't have the problem, but then again, I am not shifting quite as often. Does anyone have any idea what this could be? Thanks a lot.
Another thing that I forgot to add is the the pto always grinds a little when I engage it, it's not much but that doesn't seem right. I know that the pto clutch is disengaging.
/ trans hard to shift #2
If you are getting a grind everytime you put the pto in gear your clutch is dragging a bit. The heating and expansion might be the culprit for the hard shifting. If the tranny is a bit stiff to disengage and grinds a bit to put back in, most likely the clutch is not fully disengaging.
couple of things to check out. I ran onto a dozer with a sticky mainclutch. It freed up fine when I unstuck it, but the next day was the same. I pulled the lower clutch pan and found that the rear main was leaking and gummed up the disc. I was surprised that it didn't slip.
Another thing, if the pilot bearing is worn and lets the input shaft to the tranny sag just a little it will cause the disc to tilt ever so slightly letting the edges drag a small amount.
2012 Ford Escape SUV (A61569)
2012 Ford Escape...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
KBH Tender Trailer (A63118)
KBH Tender Trailer...
2019 Chevrolet Tahoe 4X4 SUV (A61569)
2019 Chevrolet...
(HRS SHOW-11370), EROPS, S/S, HYD TILT, 14.00R24 TIRES, 168" MOLDBOARD, DRAWBAR, S/N-DW770CH578729 (A62129)
(HRS SHOW-11370)...
New Three Point Hitch Trailer Mover (A61166)
New Three Point...
