Tranny problem
   / Tranny problem #1
Dbellrn
Mahindra 2015HST
I have a 2015 that just rolled to 200 hrs today. I was running it pretty hard moving manure up and down some really steep hills. It ran fine until the end of the day. It has the HST transmission. I tried shifting from low range to high and I could not make the shift. The high range gears were already spinning and wouldn't let the shifter engage. Thinking that the pedal may have been the culprit, I moved it up and down but it didn't change. I depressed the clutch but it didn't help either. When I let the clutch out, the mid-PTO was engaged but the lever was still in the neutral position. It will shift in and out of low range normally and moves fine in low. Any ideas?..
   / Tranny problem #2
Lower your RPM, try to be on level ground, briefly tap your forward reverse pedal while trying to shift. This always works for me. Also, at 200 hrs., make sure all of your linkages are thoroughly lubricated.
   / Tranny problem
Thanks Aching but I did all before I posted. Gonna try something else tonight.
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
