Oil & Fuel Tranny oil filter 'exploded' at startup! HELP?
   / Tranny oil filter 'exploded' at startup! HELP? #1
duck_man
It's very cold out today, -23 Celcius. After finally getting my Case DX25E started, right away the Hydro oil started pouring out from around the filter. LOTS of it. All over my beautiful new garage floor.
Could it be that the filter and the oil were frozen ? Condensation inside the filter somehow? Is there a way to heat this up - like the equivalent of an engine block heater or something? The HST, hydro systems etc all share a common sump.
This is a real pain because the tractor is parked in the garage right next to the wall with difficult access to the filter. I suppose I'll have to wait until it warms up and get a new filter and some fresh Hy-Tran in there. What a bummer I wanted to go play in the snow! In the meantime I have to go down to Wallymart and get some kitty litter.
Has this ever happened to anyone else here and if so what have you done to fix it and make sure it doesn't happen again?
Should I get one of those big diesel 'tiger torch' heaters and heat the garage up for an hour or so before I try to get the tractor going? It's not insulated yet.
   / Tranny oil filter 'exploded' at startup! HELP? #2
Must have had water that collected in the filter and froze. Better the filter than the hydro. Take the filter off and drain 'n refill your hydro with fresh oil. You might say that you are lucky to have such little damage. I have seen water crack cast iron transmission cases when it freezes.
Dusty
   / Tranny oil filter 'exploded' at startup! HELP? #3
Sorry for your problem.
Was it the proper oil,and proper hydraulic filter?It sure does sound like the oil wouldnt strain through it.When was your last filter change?
alan
   / Tranny oil filter 'exploded' at startup! HELP? #4
You might want to check into getting one of those magnetic heaters for your transmission. Do a Google search. You'll find lots of them for sale.
Ralph
   / Tranny oil filter 'exploded' at startup! HELP? #5
I agree with dusty, new Hytran and filter.
Bob
   / Tranny oil filter 'exploded' at startup! HELP? #6
While I don't discount that water could be the cause, I would more likely suspect increased pressure from the cold oil caused the filter to fail, or just leak at the seal.
New oil is cheap insurance, either way, and a new filter.
I try to keep the rpm's low on a cold startup, to keep the pressure down on the hydro.
Ron
   / Tranny oil filter 'exploded' at startup! HELP? #7
Some of the New Holland TC owners (40/45) talk about a winter hydro filter to avoid bursting on startup.
See what your dealer says about a winter filter.
Bob
   / Tranny oil filter 'exploded' at startup! HELP? #8
I have had the same issue with a kubota HST. Kubota went thru at least 3 revs of the filter to get one that is stout enough for winter use. Wisconsin sees some -20 to -30F weather.
Your tractor is probably similar to the K; Oil from the pre-charge pump gets filtered then on to the HST pump. It is in the 200-400 psi range when it is filtered. In the winter, the gasket on the filter shrinks and the oil thickens up. That jacks up the pressure, the shrunken gasket fails and you get a big puddle under the tractor. (I have had three!)
There are 3 things to do, be sure the filter is tight, change to a multi-viscosity oil like SUDT or a lower viscosity oil as recommended by the dealer and warm the tractor up for a minute for every degree below 0 C --> WITH the clutch dogged down. Then for 3-5 minutes with the clutch up. If it's above 0C, but still "cold", I just give it a couple minutes then go slow.
The HST pre-charge and main pump is not engaged with the clutch down. The regular hydraulic pump that powers the loader and 3pt is still working and will slowly warm the fluid. It would be nice to not have to do this, but....
jb
   / Tranny oil filter 'exploded' at startup! HELP? #9
Thanks John Bud.. what you describe makes sense to me after your explanation. My original thought was moisture being collected in the filter and freezing. Since others have also experienced this your theory must be correct. This old dog, just learned another new trick. :D
   / Tranny oil filter 'exploded' at startup! HELP? #10
jb
Yep, you are right on the mark. I run a JD roadgrader and although it has never puked around the filter, it will trip the hydraulic warning light telling you the oil flow is dangerously slow when first cranked on a real cold night and that's with an engine heater that warms it enough to crank like you just turned it off. But that heater does nothing to warm the hydraulics. in your case if you can depress the clutch and hold it for a minute, then slowly engage the clutch the surge will be limited and not blow off your filter. Lastly, go to O'Reilly's or Checkers or NAPA or whatever chain of auto parts store is familiar to you and buy a big bag of floor dry. You can buy a 50 pound bag for what you are going to pay for a 5 pound bag of kitty litter.
   / Tranny oil filter 'exploded' at startup! HELP? #11
It's not a theory. New Holland Boomers had the same problem and a change was made to the filter to deal with this. Tightening the filter, heating the oil, etc. doesn't help.
Thread 1
Thread 2
   / Tranny oil filter 'exploded' at startup! HELP? #12
DUCK MAN,
Looks like you got your answer.If you stick with that same kind of oil and filter,id get a little heat in that garage.The torpedo shaped reddy heaters do a good job in warming up equipment,i use one alot to thaw my snowmachine,or cars etc.Make sure you got no fuel leaks[or oil for that matter]If the object your warming is too hot to hold your hand on ,its too hot!!.You can direct the heat with a peice of tin on the heater,i lay one on mine to blow the heat on the floor ,so not to burn any paint off what im thawing.Be sure to keep your door open slightly,the fumes are a killer.
Hey guys,Am i the only one whos heard of the old timers getting a pan of hot coals to place under a tractor,or skidder to warm the oil?
ALAN
   / Tranny oil filter 'exploded' at startup! HELP? #13
escavader said:
DUCK MAN,
{snip}
ALAN
Alan, Not at all! A small habachi cooker has been used to start more heavy equipment than I would like to remember. Another old timers trick is to take the battery inside on real cold days. You can even bring it inside and stick it in a tub of hot water, then quickly put it back and VROOM!! Cranking ability is is cut in half from 70F to 20F, down to almost 1/4 at -30F. Heating the battery will restore the amps by speeding up the chemical reaction that makes the juice. But you have to be quick.
Oh, a 100w bulb under the engine is much safer than a fire. In case you didn't know... seems a lot of heavy equipment also burned up on real cold days too.
jb
   / Tranny oil filter 'exploded' at startup! HELP? #14
Bob
Yep.. I just looked thru the archives and there are many instances of this.
Soundguy
Yes it looks like it's a combo of a) HyTran - not low-temp HyTran and b)the filter (there is a winter filter I can get...now I know)
So when it warms up (this weekend!) I shall put in multi-visc oil and change the filter. I might try the lightbulb idea next time. I hate to not use the tractor because it's cold out. I also hate the stains on the floor of the garage but whatever - it's not my living room.
Thanks for all the experience and advice!
   / Tranny oil filter 'exploded' at startup! HELP? #16
Duck,
Use some oil-dry on the stain. Let it set for a week, then sweep it up and put down fresh. Then really grind it in with your boot. Grind it down to dust and let that set for a week or two. Sweep it around every day or so and it will pull up most of the stain.
Will never be perfect again, but will be much better.
jb
   / Tranny oil filter 'exploded' at startup! HELP? #17
Here's a response that I recently got from a dealer concerning the cold weather filter for our TC40D. I purchased the TZ filter but have yet to install it.
Cold weather filter SBA340500980 is listed for the TZ tractors. I didn't
see anywhere that they recommend this for the TC40D, but the standard filter for the TZ and TC40D tractor are the same number so this should work. Available in 1 day.
   / Tranny oil filter 'exploded' at startup! HELP? #18
jb
An old fella I met once in New Hampshire left his Bucyrus-Erie crawler up in the woodlot all winter. Hand-crank, no battery to worry about. If it was real cold, he'd drain the engine oil out, light a campfire and heat it up, then pour back in and crank. Gave him time to probably cut a tree down meantime. It seemed like a lot of work to me, but took only 1/2 hour probably, and the dozer saved him more than that time during the day.
Jim
   / Tranny oil filter 'exploded' at startup! HELP? #19
Amway concrete cleaner is good, and just about any 'alkali' concrete cleaner will work.
When i rebuilt the hyds in my 8n a few years ago.. i accidentally dumped about 1+ gallons of 90wt oil on the garage floor. After sopping it up with newspaper, I made a thick slurry of powdered laundry detergent ( gain i think ).. that is.. just a bit of water.. and enough powder to coat the entire stain.. make a thin paste.. trowel around with.. well.. a trowell or putty knife.
let set.. keep adding water to keep the soap powers wet.. and stir occasionally. after a few hours.. get 'the brush' out.. scrub well, and wash off.. the stain came up 99.5% on my unfinished concrete floor doing it this way.
Soundguy
john_bud said:
Duck,
jb
   / Tranny oil filter 'exploded' at startup! HELP? #20
To clean the spilt oil I have had good luck using cement, pure is best---sackcrete is ok---it doesn't set but its so fine it does a good job absorbing and then can be swept up just fine, sometimes 2 or 3 applications is needed or at least mix it around after it sets for a day or two.
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2022 John Deere 1025R (A53317)
2022 John Deere...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2018 Chevrolet Impala Sedan (A59231)
2018 Chevrolet...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
