Tranny for Troy Bilt Bronco Axis 21A-70M8766
   / Tranny for Troy Bilt Bronco Axis 21A-70M8766 #1
Chitreano
JD 2630
I have a Troy Bilt Bronco, vertical tine tiller. The unit looks very new & runs great. However, the transmission shaft & worm gears are badly worn for some reason. I could replace the shaft & gears but the cost is prohibitive for the value of the machine. I would like to find a good used transmission assembly if possible. The transmission model is 618-07010 (replaced with 918-07010) and the S/N is 1C115P20252. The tiller model # is 21A-70M8766. Any help is appreciated.
   / Tranny for Troy Bilt Bronco Axis 21A-70M8766 #2
The vertical tine tiller by MTD turned out to be a disaster project and was short lived. I suspect any used units you find will have the same issues or worse.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Sign Board (A56857)
Sign Board (A56857)
PENDING SELLER CONFIRMATIONS (A58017)
PENDING SELLER...
Water Line Hose (A59076)
Water Line Hose...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
UNUSED FUTURE...
