Tranmission/ Hydraulic Fluid
/ Tranmission/ Hydraulic Fluid #1
mark4Jesus
Sale Creek, TN
2021 Branson 2610h
I had Bush Hog FEL installed on my B2150. They topped of the trans/ hyd. fluid. This is not where I bought my tractor. The manual says not to mix different brands of fluid. Is this really a problem? Do I need to change the fluid?
/ Tranmission/ Hydraulic Fluid #2
I seriously doubt you'll have any problems, Mark. I assume "they" are the dealer, and most of them know what they're doing.
I'm for Jesus, too! /forums/images/graemlins/laugh.gif
The FEL was installed by a local farm supply dealer, not a Kubota dealer. I'm not sure why the manual says not to mix fluid from different manufacturers.
/ Tranmission/ Hydraulic Fluid #4
Mark, I'll look into this tomorrow a.m. Get back to you tomorrow p.m. /forums/images/graemlins/wink.gif
/ Tranmission/ Hydraulic Fluid #5
If you had a tractor with remotes and "Billy" borrowed your hydraulic harrow some of his "Hy-Tran" would be left in your harrow lines and cylinder(s) and it would be pushed into your system as soon as you operated it. It's probably not a good idea to mix fluid, but most tractor hydraulic fluid is compatable with each other. Super UDT is fairly unique, you will find some threads however where the Kubota dealer would recommend Hy-Tran or New Holland tractor fluid in place of Super UDT.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2021 CAM P4EC16  16ft 8000lb Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
2006 FRAC TANK 500BBL WHEELED (A63569)
2006 FRAC TANK...
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
