Trane air conditioner Good??
   / Trane air conditioner Good?? #1
coffeeman
Platinum Member
Just got price on new 3 1/2 ton air conditioner . Is Trans good choice? $3800. is total cost. Replacing Air handler inside, lines and outside air-condition unit. However, he hasn't given us any
more info than tonnage of 3 1/2 . and 10 year warranty. It's air only, no heat pump. What other questions should be asked? Our old one is 34 years old.
Cheers....Coffeeman
   / Trane air conditioner Good?? #2
I have had two of them in my home for twenty years. Just replaced the first one with another trane two years ago, the other one is still going strong.
   / Trane air conditioner Good?? #3
From what I've read Trane is supposed to be one of the best. Whatever brand your old one is - you sure got your money worth out of it.
   / Trane air conditioner Good?? #4
The efficiency rating- SEER rating is the name
   / Trane air conditioner Good?? #5
They are about as good as most anything else out there.
Your price sounds great from what I'm hearing. I would guess your equipment costs around $2800 because it is Trane.
What SEER rating is it? The higher it is, the more money it costs, but the more efficient they run.
If it were me, I'd pay a bit more to get a 16 Seer over a 14 Seer rating. If you go for a higher than 16 Seer, the systems start getting more complicated with 2 speed or variable speed blowers. These require a circuit board card. Some 16 Seer require these too. They work great when they work, but they usually have a solenoid or something on them that goes out.
Your 30+ years life of your old system is almost unheard of nowadays. I would expect you could lower your electricity for running the AC down as much as 30%
   / Trane air conditioner Good?? #6
Cheers....Coffeeman
So how old is the house? original sizing of AC unit is based on sq. footage and ideal initial install insulation.
Consider getting a SEER 1 or higher instead of the 12 or 14. The condenser unit will be larger and have more efficient heat rejection, thus reducing electrical billing. Some utilities have rebates something to consider looking into.
Trane is a quality unit. 34 years is about 14 years past due.
Is the $3800 the condenser unit and also the air handler inside?
If yes it is a good deal.
Points to consider:
What size of air filter does this unit have?
Some units have a 4" filter housing and some a 1" filter housing.
A 4inch think air filter will last longer and filter more efficiently then a 1 inch air filter. The MERV ratings are flexible and provide quality filtering options for those with allergies etc.
Now is also the time to inspect the air ducts. Are they made of sheet metal? If yes, most likely they leak and the attic is a comfy place for critters.
Speaking from experience in a 40 year old house.
So either repair and reseal the joints and have them cleaned out or replaced.
If the present unit burned out with a compressor failure, the copper refrigerant line will have contaminants and will contaminate the new unit and contribute to a possible shortened life. I had the line replaced in ours.
Ask if the installer if they will dehydrate the new unit by pulling a slow vacuum to dry out the lines from condenser to air handler unit. Many times a contractor will sweat the lines in and open the condenser and check the charge and 'trust' the installed filter dryer. This is just lazy.
When the new air handler is installed a new air box should be built to have a tight fit over the air discharge into the distribution trunk.
The base that the unit sits on is it sound? Water over flow many times leaks past the drain pan due to clogged drain and the wood rots.
So this is a point of inspection also.
lastly it should have a breaker / disconnect near the compressor. This is a great location to install a surge arrestor to mitigate potential compressor burn out from line surges during storms.
I've many thread here and I may get lots of negative comments on why not to use them.
But there is no utopia.
We research and make our best guessed decisions best on our research and your mileage will always vary.
On edit: A heat load analysis is a good idea if it is within one's budget. Or talk to your provider about a heat load assessment based on condition of house, windows air ducts etc.
Our first house was a tract house with a 2 1/2 ton unit I went up to a 3 ton unit. It lowered my monthly bill and still removed the humidity but did not work as hard. Once a house settles, insulation settles and house shifts there are countless air entry points. So a sizing chart may say 2 1/2 ton for a given square footage but other factors are at play. Our second house was 40 years old and we went from a 3 1/2 ton to a four ton for same reason, with same results.
Hope this helps you get on a good path to help cope a very hot summer.
Regards.
   / Trane air conditioner Good?? #7
Fabulous advice above.
Yes, Trane still seems to be good.
Curious, why no heat pump????
   / Trane air conditioner Good?? #8
The cost to increase SEER can be a black and white mathematical calculation based on the cost of electricity, the efficiency (insulation etc) of the home and your climate. If electricity is high and the temps are high then paying more for a higher SEER is probably worth it if you plan to live there a while. On the other hand if electricity is cheap and you are in a mild climate with a modern home paying extra for higher SEER may never pay you back.
   / Trane air conditioner Good?? #9
Ask to have a heat loss calculation done, Right J software is the industry standard. A unit that old was most likely sized strictly by the square footage of your home and did not factor in window efficiency, insulation quality, the homes orientation, basement or not, one story or two, and even what ground cover is around the home such as grass or asphalt...Right J does. The installation MUST include flowing nitrogen through the lines while brazing and pulling a vacuum on the lineset and coil before opening the valves on the condensing unit.
   / Trane air conditioner Good?? #10
The OP does not have location on his profile.
If he is up north there is point of diminishing returns on a heat pump up north.
There will not be enough heat rejection that will flow into the house.
If he lives in a more southern geographical region a heat pump is a good way to go.
Until OP shares his location, it is an unknown for us.
2010 Freightliner Sprinter 2500 Cargo Van (A46683)
2010 Freightliner...
EverRain Hard Hose w/ Nelson 200 Big Gun (A47369)
EverRain Hard Hose...
2021 ROADCLIPPER ENTERPRISES, INC. (A46683)
2021 ROADCLIPPER...
2009 BMW 750i Sedan (A46684)
2009 BMW 750i...
JCB 407B (A47307)
JCB 407B (A47307)
2015 John Deere 5085M (A47307)
2015 John Deere...
