Tramming Slow to Respond
   / Tramming Slow to Respond #1
v11m
Chicagoland, IL
PT425; Ford 2N
Hello All - hope everyone is well. So I got through the summer and fall with my new PT and got to do plenty of projects with downed trees and moving dirt... still not really satisfied with the mowing aspects (but shame on me for trying to grow grass in the woods on a sandy plot)...
I had some leaky hoses over the summer, but really didn't think much of it - just tightened them and moved on. Well at my 50th hour, I replaced the filter and noticed that the hydraulic fluid was super low, but didn't really notice the machine acting differently. I filled it back up and I noticed that it took a long time to clear the air out of the system, but the bubbles eventually stopped.
Now it is much colder now, but the PT is kept in a heated shed, albeit ~50 degrees. When I first fire her up she won't really stop when going forward (or backward) and then moving the treadle to neutral - much different than before the change (though I'm not sure if that was the cause or not as it could be the cold).
When it warms up after 10 to 15 minutes it is better, but still not as 'jerky' as when I first got her.
Any ideas? I read some posts here about a tram adjustment, but the problems didn't sound exactly the same. Maybe there is still some air sitting around somewhere? Maybe the pump is damaged... wouldn't think so, but wanted to get everyone's thoughts.
Thanks in advanced.
-D
   / Tramming Slow to Respond #2
Can't help you much on that one. Mine is a cable controlled treadle and yours is a hydraulically controlled treadle. Don't know an adjustment procedure for yours. I'd call Terry at PT tomorrow and talk it over with him.
   / Tramming Slow to Respond #3
Well you most likely have one of the new PTs with the upgraded main pump so I can't help you with that but try useing a leaf blower up and around your treadle. Take the covers off and give it a good cleaning in there. I hade this happen and it was a stupid little stick that got up in there. I would try that first and see what you find out.
   / Tramming Slow to Respond #4
There is a certain amount of delayed response just due to cold oil.
I’d ask Terry, but it sounds to me like you have air in your treadle system. IIRC, you have to unscrew the lines at the treadle, and flush oil through them.
All the best,
Peter
   / Tramming Slow to Respond #5
Slow response is normal in cold temps until it warms up. But at 50°, it should not be too bad.
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Mini Excavator Pallet Forks (A53316)
Mini Excavator...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
weber crs plate compactor (A55787)
weber crs plate...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
