Tram Leak Fun
/ Tram Leak Fun #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Todays project was to fix all the stuff I had chose not to over the past few months. I have had this nagging leak in my tram pump, where the hose comes out of the left side.
Terry had sent me a repair kit that had consisted of the two brass nozzles on the side of the pump and one extra washer (these are brass washers with o-rings built in
(see the bottom pictures on this page) USA Discount Generators - Standby and Portable Gillette Generators
These adapt from Metric to SAE. The old ones take a #18 Metric to remove. Well, I installed the replacements and one of them was not a #18 but a 3/4". Hmmmm. And when I went to replace the Hex Plugs the 3/4 was too big and blocked the hex... So, I put the new washer on the old fixture and am hoping for the best.
A bit of trivia for anyone having leaks in this area on the 1850. There is a hex plug on the underneath of the tram pump. It is a different size than the ones on the side of the pump. It takes a Metric #5 Hex. The sides take a Metric #6...
Carl
/ Tram Leak Fun #2
Carl, are you sure they are brass? Or are they just gold colored. Fittings many times have this type of coating for corrosion protection. The washers with the o-rings inside are called bonded seals. they are common on metric ports and British Pipe ports. I don't get what these new fittings would solve. Am I missing something? I do have my generator running here in the building, so maybe my oxygen is running low. 15,000 sq ft with 26' ceilings and porous as a seive, so don't worry.
/ Tram Leak Fun
I think they are brass. I scuffed one up and it still had color all the way trough
thanks for explaining what kind of washer it is. My notes say the Tram Pump is a Bondilio.. Not sure if that is true or not.
Here are a couple of pix from Ksimolo who is a much better photographer than me...
As for why I was sent the whole fitting and not just the Bonded Seals is a mystery to me. The Seals were allready on the fittings so it made me nervous pulling one off to put on the old fitting...
My supplier did not ship me any seals for the hex bolts which were leaking, so I had to go to Napa for O-rings. It will be interesting to see if they work out as they appeared thicker to me than the stock...
Carl
/ Tram Leak Fun #4
The bonded seal is 2 piece. If you take one off and it comes apart, no big deal. Just put the o-ring on first and the washer next. Some manufacturers actually sell them as 2 different part #'s and you assemble it.
The o-rings from Napa were thicker as most fitting o-rings are thicker than what comes in most generic kits. If it doesn't leak, don't worry.
The fittings are definately not brass. No big deal, just an fyi in case you order them or go to get them as brass is lower pressure.
/ Tram Leak Fun #7
Wayne County Hose said:
Hey, the more I'm looking at these Power Tracs, I just may get one.
Just keep in mind that they are not Ag tractors, nor down-sized Ag tractors called CUTs or SCUTs -- they're tool carriers that combine some of the best (and perhaps worst) features of skidsteers and articulated loaders...
They're tool carriers, not tool pullers... :) With the exception of loader work (which they're obviously well designed for, as "mini-payloaders") the hydraulics do all the work -- the PT just carries that hydraulically-driven implement and places it precisely where you want it...
IMO, that's a huge difference from traditional tractors, and really needs to be experienced to understand it. Too bad that PT discontinued its dealer network, which would've made it much easier for people to spend some time in the seat before making their decision. I'm always surprised by those who'll buy them sight unseen, without test-driving...
/ Tram Leak Fun #8
You make some excellent points. I made sure I sat on one befoe I bought it. I also spent a year researching it.
They are not AG tractors. They do not pull well at all. I don't do any pulling chores like plowing dirt. I move lose material like mulch and rock. I mow. I lift. I plow snow. It excells at these things.
/ Tram Leak Fun #9
I already have an MF-85 and an AC-WD45, and an Oliver cletrac dozer, so I've got plenty of ag stuff. I'll have to research these more as I am looking for something a bit more versatile than what I have. I was thinking skid steer, but the prices are outrageous.
/ Tram Leak Fun #11
You will find that a skid steer's hydraulics are way more powerful than a comparably sized Power Trac. Since you mentioned a skid steer, what would your uses be? I think there are several Power Trac owners with skid steer experience that may be able to tell which is better for what tasks. Maybe pose the question in a new thread here in the Power Trac forums so we don't hi-jack this one.
/ Tram Leak Fun #13
I saw mine first..... in a video! It was a hard choice between the PT422 and the PT-ATV (not really).
The PT folks must have practiced long and hard to manage to keep the same expressionless monotone voice through an hour long video...and when they listed every one of the 40 attachments for EACH version of the power trac, it was riveting stuff (my 3 yo loved it).
/ Tram Leak Fun #14
Sight unseen and one of the best investments I ever made.
/ Tram Leak Fun #15
I'll concur that it's one of the best investments I've ever made, but I spent almost an hour in the seat (totally unsupervised, too, which was great!) before I bought it. I didn't try all the attachments -- but I did try climbing hills and lifting things, in addition to digging.
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
LOT OF PVC & PLASTIC PIPE (A63291)
LOT OF PVC &...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
