Tram issue on 422
/ Tram issue on 422 #1
SwampmanLA
As anyone had a 4xx with hydraulic tram pedals just keep moving when you let off the pedals? My 2008 vintage 422 just started doing this, when I release the foot pedals it keeps rolling and slowly comes to a stop. Some opposite pedal pressure will stop the PT with no problem but the run on is new. I cleaned the muck out from under the floor boards, lubed the pedals up real good, but it still has run on. Tram still has plenty of power so I do not think it is a pump issue but a tram value issue. Ever heard of the tram valve failing on a 4xx PT?
/ Tram issue on 422 #2
Check your cable and the black round unit on the end of the cable at the tram.
/ Tram issue on 422 #4
Are there pedal return srings that may have popped out?
/ Tram issue on 422 #5
Is that pedal a spring to center valve or just a friction valve with spring assist?
/ Tram issue on 422
I talked toTerry and he asked me to reverse the two hoses from the pedals. I have been busy and have not had a chance to test it out. I will let you know what I find out.
/ Tram issue on 422 #7
my 425 has the same problem, cleaned debris out of forward/reverse tram valve, worked well for a while (20hrs) problem has resurfaced and intermittent, keep us posted what you find, check out post ''up a tree with the pt'' that was my rant. I have not had the time to investigate further the tram issue
/ Tram issue on 422 #9
it did not ''blow out debris'' on mine, it just reverses the direction the pedals work, forward pedal becomes reverse and vice versa :eek: just remember to switch the hoses back or possibly a week later while in a hurry you might forget (don't ask I won't tell)
/ Tram issue on 422
Finally had a chance to swap the lines on the 422 today. No joy, I still have the issue. Guess I'll see what Terry has for me tomorrow.
/ Tram issue on 422
Update from Terry: the tram pump has to be pulled and sent to PT for repair. Swapping the control lines tested the treadle valve and he knows it is something in the pump. Well looks like I have a project for the weekend.
/ Tram issue on 422 #14
Besides, you want to keep sand and dirt out of the lines...
All the best,
Peter
/ Tram issue on 422
Cleaned the tub out very well so dirt is not an issue. Numbered all lines and took pictures as I took it apart. Actually taking it out was easy. The prep took all the time. Tram pump gets shipped in the morning.
/ Tram issue on 422 #16
My vintage PT-422 has two return springs in the pump control cable that runs between the treddle and pump. It is encloded in a black platic housing about 2" in diameter and 4" long. It povides a spring return force in both directions.
As with all springs,,,,they weaken with use. Further, as the inevitable decay with time, the cable moves less freely as the lubrication escapes or wears. Weeker spring and harder cable pull both work to make it harder for the pump to center.
Check cable lubrication as well as the springs in this assembly.
/ Tram issue on 422 #17
As was mentioned earlier, the OP's PT doesn't have a hydroback cable. It has the newer hydraulic valve treadle instead.;)
/ Tram issue on 422
Well Terry called with the results of my tram pump post mortem. Seems that a spec of something got in the closed loop system of the tram circuit and scratched a plate in the pump. It is all fixed, boxed up, and hopefully on the way back to me. I have no real idea of what they changed in the pump bug all I really know is it cost a grand to fix. Ouch! I love my PT so I would have paid more to get her back running. I just hope she stays fixed for a long time.
/ Tram issue on 422 #19
Ouch indeed...! I have to wonder how much a local hydraulic shop would've charged to service that pump...
/ Tram issue on 422
And the saga continues. Got my repaired pump back and installed. Found that I had reverse but no forward motion. A few calls to Terry and all he could say was to send the pump back to him for additional inspection. So I pulled it and boxed it up today.I hate being without my PT but right now I have no choice.
KBH Tender (A63118)
KBH Tender (A63118)
DSP 900 Balancer with Split Weight (A63118)
DSP 900 Balancer...
Ingersol Rand 175 Air Compressor (A64047)
Ingersol Rand 175...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
ALUMINUM HEAD ACHE RACK (A63569)
ALUMINUM HEAD ACHE...
1996 International Water Truck with a Caterpillar Engine (A63118)
1996 International...
