training a Horse to "go" outside
   / training a Horse to "go" outside #1
scesnick
Garrett County Md. ( Western Md.)
Kubota MX5100
I have a 4 yr. old Morgan and she is in the habit of going into her stall to relieve herself. ( I guess she is just shy ) But, I am tired of shoveling out her stall.
She has total freedom to our pasture and can come and go whenever she wants into her stall. She just chooses to "Go" in her stall.
Is there any trick to teaching her not to do this??
BTW, I'm not the horse guru, It is my wifes horse, i just get to maintain the fence, shovel manure and keep the small barn squared away. You know, the stuff I am contractually obligated to do through marriage.
Jimbrown said:
Sigh Close the stall.
Maybe i should have added that this is mostly a winter time problem and my wife would rather see me freeze to death than the horse..
Closing the stall is not an option in the winter.
   / training a Horse to "go" outside #5
Train a horse? Is that possible? My wife has a mare that waits for me to open the barn door every morning. As soon as I enter the barn, I hear her urinate in her stall, even though she will be put out (after grain) in about 5 minutes. I usually remember to thank her for the extra work! The geldings sometimes go from outside the barn back into our run-in stall to urinate. They don't seem to want to spray their legs.
   / training a Horse to "go" outside #6
From what I have heard/read/seen about training horses, it is a lot like training dogs(or anything else for that matter). I have never trained a horse, but I have trained many dogs.
1. First you need to catch them IN THE ACT of performing the undesired
behavior.
2. Then you need to have the ability to modify that behavior IMMEDIATLY.
3. You must be very consistent in the aplication of whatever you use to
modiy the negative behavior(must catch them EVERY time).
4. You must be even MORE consistent and timely with the praise and rewards
as re-enforcement when the correct behavior is exhibited.
Training collars and invisible fencing for dogs are very effective because they provide Immediate behavior adjustment. Electric fences with horses work the same way. I mean you can effectively corral a thousand pounds of animal with a 18 gauge piece of wire that they could break without much effort but they don't unless highly motivated by something else. I do not think a taining collar would be appropriate In the case of a horse, but perhaps a loud unpleasant buzzer or siren in the stall would give you the ability to quickly move the horse outside. Of course the horse must be able to get outside unassisted/unobstructed. If you are able to do this every time, the animal should quickly get the idea that every time she trys to relieve herself in her stall, that loud scary thing goes off, but that never happens when she goes outside and when she goes outside, her master is happy, praises her and she even gets a treat sometimes.
Unless you are prepared to spend a lot of time in the barn to catch the horse every time she starts to relieve herself and shoo her outside, you need some way to automatically detect the act. Perhaps a moisture detector on the stall floor below the chips, sawdust or straw, or a sound activated switch with a mike down low in the stall and set up for a particular frequency of liquid or semi solid splattering on the floor. Anything automatic has to be very selective and timely lest you start correcting her for doing normal allowed behavior or you correct her too late after the deed is done. If the thing goes off for other than the desired reason/time, you will just confuse her. Habitual behavior is also hard to break. You have to be in this for the long haul. If the behavior modification stops, the old behaviors will most likley return. That is probably where the saying "You can't teach an old dog new tricks" came from. Well you can, it just takes more work.
RonMar,
Thanks for the tips. I don't think the loud siren would work. I think she would get caught one time, get scared half to death by the siren and NEVER go back into the stall again.
I tried to catch her to put a halter on her once in her old barn when she was ajust weened and she refused to go back into that stall ever again.
If you think dogs can be hard headed, you should try a horse !!!
Thnanks for the tips though. I will try something to that effect.
   / training a Horse to "go" outside #8
Sounds like a good way to get too build a new stall!:D
   / training a Horse to "go" outside #10
I had two horses in box stalls right next to each other. One horse would wait until she got outside to relieve herself and the other would wait until she was in the stall before she went.
That horse would be outside all day and as soon as she got in her stall she would pee. She did this from day one, don't ask me why.
Good luck!
Randy
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2016 Ford F-750 14FT Utility Flatbed Truck (A52377)
2016 Ford F-750...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2003 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRUCK (A54756)
2003 FREIGHTLINER...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
