trailers for tractors
/ trailers for tractors #1
Agvg
Elite Member
Norway
Mf135, Ursus C-355, David Brown 995
What do you use?
Can't say its a frequent topic here so I become curious on this.
/ trailers for tractors #2
If you mean a trailer to haul my tractor with I have a 22" PJ 14K tilt bed and a 16' 14K dump trailer.
I have towed both of these behind the tractor also but don't have a dedicated small trailer to tow with the tractor.
More a trailer you haul with your tractor.
Things like this
/ trailers for tractors #5
I have a 6'x8' Carry-On that I use for both behind the car and behind the trailer.
/ trailers for tractors #6
For some reason, for use on the public roads, it is not as popular on this side of the ocean. :confused3:
This is what I use when I need to use the dumper and the V417 to load it.
Haul the EV to the jobsite, unhook the trailer, then drive back to get the dumper.
Strange, its a very versatile combo.
My trailer, a more modest size
/ trailers for tractors #10
My trailer for hauling the tractor and my trailer for pulling behind the tractor are the same. In both cases a 14'x7' (deck between wheels), 10,000 GVW flat bed with wood sides.
/ trailers for tractors #11
I built this 5' x 6' for my JD 790, using parts I had on hand: FARM 045 (Small).jpg FARM 046 (Small).jpg Would have been nice to have a bit more tongue weight, but I didn't have room with what I had.
Nice build
/ trailers for tractors #13
Homemade from scrounged parts. I only bought the fenders.
Yes, a good back yard with "junk" can be a source for much fun if you have a welder and tools.
/ trailers for tractors #15
My deck-over 5ton dump trailer behind my tractor is indispensable to me.
/ trailers for tractors #16
I like trailers as they avoid the law better than old trucks !
/ trailers for tractors #17
Got a couple homemade trailers.
Built as wood haulers, no suspension and truck axles. But have hauled large rocks, dirt, manure, lumber, etc. Even hauled mowers on the one that has removable sides.
The small one is 4x8 with 24" sides
The large one is 4x9 with 30" sides.
Both will handle a good load of wood.
The trailer I haul the tractor is is a bit much to do anything other than just jockey around with the tractor. Its a 25' GN that weighs 6500# empty. Dont think road gear with a load of firewood is a good idea. Besides it would take way too long to fill it with wood even if I only had 1' sides.
/ trailers for tractors #18
I have an old New Idea manure spreader converted into a wood trailer approx. 4 x 12...haul a good 2 face cord per load.
Also have a JBM 8 ton dump trailer , I think is 8x12 or something like that.
And a platform wagon 8x14 with 8 ton running gear.
For my SCUT...a 4x6 JBM 1.5 ton dump trailer.
/ trailers for tractors #19
Is the chains in the spreader still hooked up?
Dad always told me about a wood hauler that grandpa had that was a manure spreader without the paddles on the back. But the floor chains still hooked to the PTO gearbox. Made it nice to unload.
/ trailers for tractors #20
A Couple of miscalculations as far as a trailer for your tractor.
And then a trailer for your tractor, high floatation was the idea!
Miscellaneous Generac Generator Accessories (A66734)
Miscellaneous...
PORTA POTTY (A67714)
2006 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2006 Hypac C530AH...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
HYDRAULIC MANIFOLD SKID (A67714)
HYDRAULIC MANIFOLD...
