Trailering thy Tractor
   / Trailering thy Tractor #1
g42guy
Minneapolis, MN
Kubota BX2200, '55 Farmall Cub, '57 Ford 640
OK, I got a shot at a Ford 2N. Web sites have it weighing in at 2300-2500lbs.
I have a "single axle" trailer with 3500lb rating and a small SUV rated at 3500lb towing.
Now I know this may not be the best solution, but by the numbers it looks like it is within the limits. It is for one trip of about 225 miles.
Opinions???!!!!
   / Trailering thy Tractor #2
What kind of roads and speeds will you be travelling?
Does the trailer have brakes?
Egon
   / Trailering thy Tractor #3
How much does the trailer weigh?
   / Trailering thy Tractor #4
I think you'd be better off renting a 2-axle trailer with brakes if this a "once-only" trip. If you're on flat terrain and you keep your speed at 55 and keep overdrive turned off, your SUV can probably handle the load, especially this time of year with cooler air temperatures helping keep your engine and trans cool.
   / Trailering thy Tractor #5
Even if the trailer weighs 1000 lbs you're still in the towing range of your vehicle. Be careful and drive way ahead of you and the guy in front of you and you'll be fine.
Hiways, 55-65, but would most likley keep it down around 55mph.
No, trailer does not have brakes.
Don't know how much the trailer weighs. It is a pretty standard design 6.5'x12' with a ramp and 2"x10" plank floar.
   / Trailering thy Tractor #7
I have done something similar, with a Kubota B9200 and a two axle light duty trailer. The distance was short and I will NEVER do it again. The trailer had been used to haul hay so I know I was not over the limit on it, but I was way too close for comfort. Borrow or rent a proper two axle trailer and enjoy the trip. That distance is a long way to go while wondering if you are going to create an accident.
   / Trailering thy Tractor #8
No trailer brakes. A load that probably weighs almost as much as the SUV.
Best to think of some other means of transportation. It may cost more but be cheaper in the long/ or is short run.
Egon
Thanks guy's. I have decided to hire it done if I do purchase the tractor.
   / Trailering thy Tractor #10
I think thats the right call....
but just to add one point, I think you would have a tongue weight problem.
Big difference between a single axel and a double axel trailer as far as tongue weight. That load on a single axel trailer would likely exceed the 500 lbs rating of most hitches.
Fred
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
1999 Ford F-550 Service Body (A47384)
1999 Ford F-550...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
John Deere 6100D (A50120)
John Deere 6100D...
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
