Trailering 7610/Gross weight???
   / Trailering 7610/Gross weight??? #1
53gravely
NJ/VT
Kubota 7610 HSD
Hi all-
I want to bring my 7610 down from VT to NJ to regrade and do a new lawn and do some work at our church. I was recently "blessed" with the Buildings and grounds chairmanship. Tractor would be here 2 weeks then back north.
I was thinking of renting a UHaul car trailer but they require a vehicle with a towing capacity of 5000#....my vehicles have 3500# capacity. Anyone have any other ideas...Double axle Landscape trailers have enough capacity?? Also what is the weight of the tractor....got some of it off the website:
tractor #1,360
Loaded turfs #500?
352 FEL with undercarriage is what...maybe #600 or what?
What about covered rental trailers?
Any ideas or experiences appreciated.
   / Trailering 7610/Gross weight??? #2
Hi Gravely,
I have yet to "own" my 7610, dealer is waiting for R4's to come in... hopefully by next weekend! But when I asked about trailering he said I could get away with a single axle trailer although it wouldn't be recommended for long trips. Dual axle is highly recommended.
Weight for the tractor/tires are right on (again, based on what the dealer said) but the 352 FEL is around #850. I hear most single axle trailers are rated at 2500lbs thus this tractor would be just over the limit.
My dealer is 40 miles away over a few steep hills and he thought I could get away with a single axle if I need it serviced.
Just make sure to get the correct length trailer! Check out some other trailering posts. They recommend going a few feet longer than the tractor.
For now I'll keep dreaming of things to do with the 7610.
Good luck!
Keith
   / Trailering 7610/Gross weight??? #3
I'm passing on trailering my L2500 (about 2400#) on my single axle trailer. Maybe ok for a few miles but I think the load on a bounce would be to much and centering the load might be harder. I just sold the 5x12 today (3500# axle) and started building a tandem axle sled. With the tires I have the gross is 4500#. The trailer will weigh about 1000#.
   / Trailering 7610/Gross weight??? #4
If your vehicle can only pull 3,500 lbs, it seems your vehicle is going to be the problem. The trailer, tractor & accessories will be more than 3,500lbs. Even the lightest double axle trailers weigh over 1,500 lbs alone.
If you lived closer by, I'm sure I could help you out. NJ is not far, but VT is.
2018 HINO 195 16FT BOX TRUCK (A52576)
2018 HINO 195 16FT...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
