Trailering 7610/Gross weight???
   / Trailering 7610/Gross weight??? #1
53gravely
NJ/VT
Kubota 7610 HSD
Hi all-
I want to bring my 7610 down from VT to NJ to regrade and do a new lawn and do some work at our church. I was recently "blessed" with the Buildings and grounds chairmanship. Tractor would be here 2 weeks then back north.
I was thinking of renting a UHaul car trailer but they require a vehicle with a towing capacity of 5000#....my vehicles have 3500# capacity. Anyone have any other ideas...Double axle Landscape trailers have enough capacity?? Also what is the weight of the tractor....got some of it off the website:
tractor #1,360
Loaded turfs #500?
352 FEL with undercarriage is what...maybe #600 or what?
What about covered rental trailers?
Any ideas or experiences appreciated.
   / Trailering 7610/Gross weight??? #2
Hi Gravely,
I have yet to "own" my 7610, dealer is waiting for R4's to come in... hopefully by next weekend! But when I asked about trailering he said I could get away with a single axle trailer although it wouldn't be recommended for long trips. Dual axle is highly recommended.
Weight for the tractor/tires are right on (again, based on what the dealer said) but the 352 FEL is around #850. I hear most single axle trailers are rated at 2500lbs thus this tractor would be just over the limit.
My dealer is 40 miles away over a few steep hills and he thought I could get away with a single axle if I need it serviced.
Just make sure to get the correct length trailer! Check out some other trailering posts. They recommend going a few feet longer than the tractor.
For now I'll keep dreaming of things to do with the 7610.
Good luck!
Keith
   / Trailering 7610/Gross weight??? #3
I'm passing on trailering my L2500 (about 2400#) on my single axle trailer. Maybe ok for a few miles but I think the load on a bounce would be to much and centering the load might be harder. I just sold the 5x12 today (3500# axle) and started building a tandem axle sled. With the tires I have the gross is 4500#. The trailer will weigh about 1000#.
   / Trailering 7610/Gross weight??? #4
If your vehicle can only pull 3,500 lbs, it seems your vehicle is going to be the problem. The trailer, tractor & accessories will be more than 3,500lbs. Even the lightest double axle trailers weigh over 1,500 lbs alone.
If you lived closer by, I'm sure I could help you out. NJ is not far, but VT is.
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
