Trailer
/ Trailer #1
B7510HSD
Kamiah,ID
Kubota B2601
Ok I'm going trailer shopping with hopes I can find one I have a B7510hsd with backhoe any idea's on the length I need and will my truck haul it ok I have a Dodge Dakota with the v8 and the trailer pakage rated at towing 5500# ?? :confused: :confused:
/ Trailer #2
Tractor Data .com says your tractor weighs about 1367lbs. Don't know the weight of your BH. do you have a front end loader? Tires loaded?
I think you will probably be fine with a twin axle 7K trailer (16')but you may want to check your local regs about matching trailer capacity with towing capacity.
Have fun trailer hunting!!
Chris
/ Trailer #3
I have a B7610 HST with FEL and have hauled it all over the place on a 16' double axle trailer, brakes on all four wheels, with a V8 Dakota. All I do different from normal driving is lock out the overdrive, otherwise it shifts too much.
16' is just enough with the BH and FEL both mounted. Any larger tractor and it would not be enough. If you don't expect to upgrade anytime soon then the 16' will be good, otherwise you might want to consider 18'. Always have brakes on anything bigger than a light utility trailer IMO.
/ Trailer #4
My 16 footer (7000lbs) works great for my tractor with BH and FEL. Total weight of T+L+B = 2800lbs.
I park the Box blade on the front under the FEL bucket.
My Dakota has manual so I don't have to worry about overdrive.
I find the brakes on the flatdeck trailer don't feel as effective as those on my FIfth wheel trailer.
I don't go any longer because the 18' would put me over the Max 40' total for some of the ferries around here.
/ Trailer
Thanks guys I stopped by today and checked them out the wife says get the 18' I won't be upgrading tractors this is all I will need I went over kill when I bought it!! :p Now to decide if I want dove tail or tilt she says it's up to me??? Sugestions???
/ Trailer #6
I found the dovetail or tilt option added a big chunk to the price tag. Since I'm not using it every day I went for the slide out ramps.
One thing that is a pain is my Backhoe drags going on/off because the ramps are too steep. The rental I tried before was like that too.
I plan on some 2x12 pads under the ramps to get the back wheels up that extra bit before i get to the ramp itself.
/ Trailer #7
My 16 footer will hold my 7510 with the FEL and RB on. The RB drags so I built some ramp extensions. Makes for a more gentle angle for loading too.
BTW I use the ramps and extensions to remove and sharpen the MMM blades. Just drive up to the edge of the deck then lock and chock the wheels. Full access to the underside of the MMM.
/ Trailer
Thanks for the replies I can get the dove tail for $100 more but the tilt is $600 more The dealer says you loose clearence which makes sense with the dove tail but I won't be useing this trailer often either and I don't believe the clearance will be an issue!??:confused:
/ Trailer
Do you guys with the Dakota's use the load leveling hitch???? I was hopeing not to need one with the tandem trailer and the BH on the rear should take most of the weight off the front??:confused:
/ Trailer
Bump anyone have a picture with the tractor and BH loaded on the 16' ??:confused:
/ Trailer #11
You can always cheat a bit and let that hoe hang over the rear of the trailer.
I'm real careful to jeep the bulk of the tractor over the axels for even weight distribution.
/ Trailer #13
/ Trailer
I was hopeing to not have any overhang but......Man I wish I could see a picture of a 16' with the tractor and BH like mine loaded up! :(
/ Trailer #15
I will try to upload some pics of my trailer tomorrow. I have a B7610 w/hoe.
The pics I have now will not upload?? Will try a different camra that hasn't had problems.
/ Trailer #16
My backhoe transport.
Doug
/ Trailer #17
Here is the only shot I have of the tractor on the trailer. The backhoe is right at the back of the trailer. Balance is good with the box blade.
No load leveling hitch used. I already had an extra leaf put in my rear springs as the dakota stock springs are soft and would drop most of the travel with only 600lbs in the box.
/ Trailer #18
Don't have a picture of your model of tractor, but, this is a Mahindra 2615 (I thinks it's larger then the Kubota your speaking of) loaded on a 16' dove tail with the box scraper up front, brush hog attached to the back, farm blade on top of mower. There would be plenty of room for a backhoe without the mower and box up front. Under the 7000 GVW trailer weight (trailer, tractor, implements) and I pull it with a 1/2 ton Dodge (Hemi). Pulled it over a 4500 ft pass with a 7% grade on the other side and trailer handled well. I don't pull it all the time, but the 16' works for my needs. Bought the trailer new with 4 electric breaks and break away system for 1795.00. It also serves as a dump trailer (with sides and steak pockets), hauling lumber, a car, etc.
/ Trailer #19
One more pic. Brush hog wheel hangs off the back a little but not enough to even justify a red flag attached to it.
