Trailer with dovetail or not?
   / Trailer with dovetail or not? #1
CJONE
Northern Michigan
KIOTI DK50 HST
I have been around heavy equipment for years and 1/2 of my trailers had dove and the other were straight. I am going to have Loadtrail build a trailer for me and I cannot decide. The option I am looking at is the 4" miltipurpose equipment dove assembly on a 22' trailer. Either that or a 2' with flip up ramps. I have major concern and that is ground clearance for the 4' dove. I looks to be about 16" and I hope that will be enough but that is why I am asking opinions. CJ
   / Trailer with dovetail or not? #2
I think a lot of it depends on where you will take the trailer. If you will be going up a lot of hills and sharp breakovers, sometimes a dove tail will be more likely to drag. I've got a dovetail, but much smaller than you are looking at, and I've only drug once, going into a concrete entrance once. For me its not a problem.
   / Trailer with dovetail or not? #3
For me I like flat decks. I had a DT but for me it was wasted space 99% of the time. My low boy with 5' ramps is plenty comfortable to load.
Chris
   / Trailer with dovetail or not? #4
You might check Corn Pro, I believe they have one where you can adjust the tail up to make a flatbed.
Chris
Thanks Chris, I agree thats why I am looking at this option. When it is flipped up and over it is a flat deck all the way back. You can also pin them straight up if you need the extra room with something loaded. Looks like a very good option. I have bent every slide in ramp I have used except for my 10K trailer I have now, I think mainly because I built them out of square tube and I have not loaded anything over 8000lbs on it. I think the fixed ramps will be stouter for the 11000lb loader I have.CJ
   / Trailer with dovetail or not? #6
I like the dove tail for loading cars and my small JD 2520. That is what I use it for mostly, but it does drag a bit in the right circumstances. It also isn't a deck-over so the ramps doesn't make it a steep climb. I have slide in ramps and on occasion couldn't pull them out the rear either due to the dove tail.
I am assuming you are going for a deck over? Dove tail wouldn't drag as much in that case.
   / Trailer with dovetail or not? #7
If you are going offroad, a hydraulic dove is the way to go. I drag the dovetail constantly, but its so much quicker and easier than slide out ramps that I deal with it. At least until I get the 30' hydraulic dovetail.
Sent from my Milestone X2 using TractorByNet
   / Trailer with dovetail or not? #8
some people like dove.. some hate it.
if it's a deckover.. the dove drop should give you plenty of clearance.
a 4' dove is more useable deck than 2' deck plus flip up ramps..
your call..
No, no more off road, thats why I have the tractor. No more truck and trailer in the woods, I am done with that. It is not a deck over, I have acess to a 3 axle deckover gooseneck that I use and I prefer the drop trailers. Thanks everyone, the 4' it will be. CJ
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
2016 Doyle 10T Tender (A56438)
2016 Doyle 10T...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
iDrive TDS-2010H...
CATERPILLAR 299D SKID STEER (A60429)
CATERPILLAR 299D...
