Trailer wiring,anyone know
   / Trailer wiring,anyone know #1
redharley
central, Pa
BX2230
Hey guy's I got a new trailer a 16 footer with electric brakes.My question is this, my old 4 wire plug needs changed to a 7 wire.Is there a place I can get just brake light power to operate the brake control other than at the brake light switch.I have a 95 Chev. Tahoe. the switch looks like a real pain to get too.
   / Trailer wiring,anyone know #3
NAPA, Shucks, Pep Boys, et al should have a simple plug-in that plugs in at the wiring harness under your rear bumper. It's a simple unplug your old connectors and plug the truck's connectors into the adaptor. You then connect the wires from the adaptor to the plug. It'll look like a factory job instead of a cut-hack job when you're finished.
   / Trailer wiring,anyone know #4
   / Trailer wiring,anyone know #5
The connector that the previous poster refered to will only give you brake lamps and signals.. no brake action. To get the brakes.. you need to buy a controller. amny vehicles have the option plug under the dash where your knees are... it's a standard plug, and you can get a kit. TSC sells the plug kit, and the controllers for a decent price.. then you would need to run the extra wireing back to the trailer plug and convert to a 6 or 7 pin plug. Will also need either a CB or fuse depending on your model of truck.. many GM's use a big fuse under a cover under the hood..
Soundguy
   / Trailer wiring,anyone know #6
Soundguy
   / Trailer wiring,anyone know #7
As stated above you will need a brake controller if you want to use the trailer brakes. A brake controller kit comes self contained with everything you need to wire the drake controller in except the round 7 plug itself.
As far as converting your flat 4 to round 7, check out auto parts stores, Tractor Supply type places or even the internet. You may be able to find an adaptor to go from flat 4 to round 7. That would save you any cutting or splicing, then all you would need to do is wire the controller in. If you cant find an adaptor thats ok, converting it from flat 4 to round 7 is simple and only takes a few minutes. No reason to go chasing wires if you have access to the rear of your flat 4 plug. as all the wires are color coded and match right up. Just buy a round 7 plug and cut and splice your existing flat 4 wires into it. You can do this and not use the trailer brakes just to get the trailer home and install the brake controller later.
When I installed my brake controller and round 7, I just cut and spliced wires from my existing flat 4 but I ran a T off of the wires so I now have both flat 4 and round 7 mounted under my bumper ready for whatever trailer Im using.
   / Trailer wiring,anyone know #8
   / Trailer wiring,anyone know #9
Technically, you could probrably tap into the brake light power to initiate the brakes, but light switches are on/off only. Do you really want your trailer brakes full on or full off whenever you tap the brakes in the truck ?
Definitly get the brake controller, you can get them for as little as $100.
   / Trailer wiring,anyone know #10
2012 Dutchmen Voltage V3950 42FT 5th Wheel Tri-Axle Toy Hauler Travel Trailer (A51694)
2012 Dutchmen...
2006 International 4400 Lift All LOM15-55-1S 60FT Material Handling Bucket Truck (A51692)
2006 International...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A53843)
2015 MACK CHU...
2023 ARMOR LITE TRAILER BELLY DUMP TRAILER (A53843)
2023 ARMOR LITE...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
