Trailer Troubleshooting?
   / Trailer Troubleshooting? #1
tex25025
Does anybody know if there are manuals, websites or something that I can look at to get a wiring diagram and discussion on how to trouble shoot trailer brakes(either 2 or 4 systems)? I'm checking for a short as my tow command system(the ford intergrated trailer braking system) won't work if it senses problems. I have checked using an ohm meter and the only time I don't get a read is on the brakes, I jump the brake wires at the trailer plug and test the line on the end that attaches to the brakes themselves and I get a signal, so it is something to do with the brakes and I don't know enough about troubleshooting them in order to determine what is wrong. Any thoughts, suggestions, ideas? Thanks.
   / Trailer Troubleshooting? #2
Have you checked the plug on the truck to see which wire is hot when the brakes are applied? You may have to rewire the trailer plug to match the truck plug as there is no set standards for vehicle/trailer wiring. I had to do this with one of mine.
   / Trailer Troubleshooting? #3
Make sure you have a good ground. If yours is like mine & used very little , the trailer sits out in the elements & things start to rust
   / Trailer Troubleshooting? #4
I had HUGE problems with a trailer that would work great with 2 of my tow vehicles but would not work at all with one of my vehicles (a Touareg). It had me baffled for almost a year. It turned out that the trailer, which was wired with all super efficient LED lights, did not have enough of an electrical draw to work properly with the truck wiring of one vehicle. But like I said, it worked perfectly with my other 2 tow vehicles. The fix ended up being very simple, but it took a year to figure out. The LED's simply didn't draw enough current and the truck's electronics were so sophisticated that it presumed the trailer was not wired properly. Ultimately the rear trailer light modules were replaced with inexpensive incandescent lights and everything has worked perfectly since.
If you are dealing with a new trailer and an existing truck, or a new truck and an existing trailer, its worth checking to see if the lighting types are compatible.
   / Trailer Troubleshooting? #5
Several years ago, I bought a book from the Good Sam Club that was a general RV maintenance book and had an excellent chapter on electric brakes, but I don't know where to get that information now. The last time I worked on electric brakes that were not working was on my brother's fifth-wheel RV. The brake wiring was run through the axle tubes and he had driven enough on bad roads that it had moved around inside the axle until it wore the insulation off the wire and let it ground itself. To make matters worse, there was some water inside the axle tube with the bare wire.
As a fail safe to protect the truck, if the tow command system sense a short or electrical problem in general it denies power to the trailer in order to protect the truck.
Strange thing is that I have had the truck and trailer the same length of time(little over a year) and it had worked up until now.
It had tested good when I jumped the brake wires at the plug and ran the ohm meter on the brake end.
My wires are exposed and they run along side the rear axle and to me they all look good. I believe it is something directly related to the brakes.
This particular flatbed and truck are the same age and both have worked fine up until just last week when I was hauling my 1435 to the shop.
   / Trailer Troubleshooting? #8
All your brakes are tied together, if one has a shorted magnet or shorted wire then your controller won't work. Check for the obvious easy stuff then start removing wheels and hubs.
Farmwithjunk said:
Try this site for some very basic info
http://www.farmco.com/technical%bulletins.htm
Keep in mind about 75% of trailer electrical issues involve bad ground.
Link wouldn't work, said the page was no longer valid. Also I had put the ohm meter on there to check for continuity, if it was a bad ground wouldn't one symptom of that be that nothing would register has having a stable connection, since your putting one connection on the ground wire and the other one at the various other connectors(right turn, left turn, brakes, running lights etc.)? How would you check for a shorted magnet? I'm pretty sure if it was a shorted wire I wouldn't read continuity when I bridged the ground and the brake wire at the plug and unhooked it from the brakes and tested it then with the ohm meter and I do get a signal when I test the wire with the brakes disconnected, but when I run the test with the brakes going thru the wire is when I don't read continuity.
   / Trailer Troubleshooting? #10
Can you (or) have you jacked the trailer up & run a hot wire straight from the batt. & connect it to the hot wire going to the trailer brakes ? ( without going through the brake controller ) If the wheels lock down doing this , I would say it is the controller.
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
TRUCK FLATBED (A52472)
2015 FORD F-450 SERVICE TRUCK (A52472)
2015 FORD F-450...
toro turf sweeper (A50324)
toro turf sweeper...
