JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,983
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Say there AxleHub: Ookla did not mention a backhoe in the initial post and it does not show in the pictures he posted on the first page. I see now that the GC1720 model means one with a backhoe. The tire loading and MMM do add to the 2670 lbs of shipping weight listed for it. So lets call it close to 3000 lbs for round numbers. I agree a little heavy for the 6 1/2 x 12 foot trailer with typical axle.
On the other hand your GC1715 should fit a 6 1/2 by 12 trailer nicely. Length is not an issue and width is fine if you get 6 1/2 ft wide rather than the 6ft. I had that width issue with my Kubotas having 60" decks and the 6" extra width makes all the difference.
Note also that Dexter makes both 5200 and 7000 lb rated single axles so one does not have to go to a tandem unless you want to. Mine with the 3500lb axle seems to be fine and not stressed a whole lot.
