Trailer Tongue Box
   / Trailer Tongue Box #31
It would be easier to tell what is right with the box. The biggest issue is the lid. It has a 1/4'' gap on one side and over 1'' on the other, it does not seal. At first I thought they did not have it centered but the lid is just made wrong. Some of the rivets that hold the hinge on are loose. Nothing is square on the box. You can lay a angle finder on the side of the box and move it to the lid and they are different. The handle that opens the box is crooked. There is paint or powdercoat chipped is off the lid in a couple of places. Both sides of the box have bulges in them. If I put it on my trailer everyone would think got the trucks bumper into the box and messed it up. Worst of all the box has a big decal on the inside of the lid that says "Proudly made in the USA". If they would have used some pride when they built the box it would be a nice box. I sat it on the trailer and it fit the trailer nicely. It is a shame it is not constructed properly.
That's really sad...You gotta figure that they have jigs and some degree of specs to build the box...Granted I can't mass produce them, but I can do better than what you described...Made in the USA---I'd have left that part out if I were the manufacturer along with my brand name if it's as bad as you state..And I believe you. Sadly.
This box was made my by Tradesman, a Lund company. I should have taken some pictures of it before I boxed it up. My $60 Harbor freight box is better than this box. The worst thing about the Harbor Freight box is you can open it with it locked.
   / Trailer Tongue Box #33
I keep a bottle jack in my little trailers box. I put a bottle jack in the truck when I use the car trailer. I have a tool set I keep in the truck that I could use change the flat. Something else that is good to carry with a car trailer is blocks to put underneath the back of the trailer to keep from picking the truck up off the ground.
i forgot, i also store 2 manual jacks to let me load heavy drive on loads....had to make these as the trailer didnt come with any means to do it. they csn either stay on trailer, or be removed and stored in box.. i usually store them in box. TRAILER BRACKET 1 copy.jpgTRAILER BRACKET 2.jpgTRAILER BRACKET 3.jpgTRAILER BRACKET 4.jpg
   / Trailer Tongue Box #34
   / Trailer Tongue Box #35
I love that idea! Here's a pic of my tool box bought at Princess Auto on sale.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=362835"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=362836"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=362837"/>
Galvanized and surge brakes. I like it. Are they drum or disc brakes? I converted my two drum brake trailers to disc and they are night and day better. So easy to sevice, no adjusting, idler hubs, ect. I will never own anthing again with drums.
Chris
   / Trailer Tongue Box #36
They are drums. I do agree that disc brakes works great but I never had problem with the drum brakes yet. The trick is to make sure you have them well adjusted to eliminate the back lash when braking. The boat that you see in the back have the disc brakes.
   / Trailer Tongue Box #37
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=362839"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=362840"/>
Yea, I have serviced boat trailers since 1992 as a part time jobs. I have probably done over 500 drum/shoe/bearing jobs.
Chris
Amazon is on the ball. The box was dropped off at the UPS store this morning and they already gave me a refund.
i forgot, i also store 2 manual jacks to let me load heavy drive on loads....had to make these as the trailer didnt come with any means to do it. they csn either stay on trailer, or be removed and stored in box.. i usually store them in box.View attachment 362817View attachment 362818View attachment 362819View attachment 362820
I have been thinking about doing something like that since I saw bubbacause77's trailer rebuild thread. http://www.tractorbynet.com/forums/trailers-transportation/292956-trailer-rebuild-summer-i-will-2.html Harbor freight has some jacks for under $30 that I have had my eye on.
View attachment 362835 View attachment 362836 View attachment 362837
That is a nice box especially for the money.
Chris
Are all trailer disk brakes hydraulic?
   / Trailer Tongue Box #39
No, some are electric. They are actuated by the brake controller in the tow vehicle which in turn powers a trailer mounted hydraulic power pack that in turn actuates the brakes. The system is called a electric over hydraulic system.
Chris
   / Trailer Tongue Box #40
For my dual axle trailer, I don't carry a jack, but do carry a trapezoid block of wood. If I get a flat on one side, I can drive the good wheel onto the block and change the flat.
That box sounds awful -- seems like they really let a piece of crap out of the factory, or something went really wrong. My Tradesman box doesn't have any of those issues. Either I got real lucky, or you got real unlucky!
I believe Northern Tool sells Tradesman boxes as well. If you can't find an alternate brand to buy, you might be able to look at them at Northern to get another idea about the typical quality.
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2021 HITACHI ZAXIS 35U EXCAVATOR (A51242)
2021 HITACHI ZAXIS...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2020 Kubota Sidekick RTV-XG850 (A47384)
2020 Kubota...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
