Trailer Tire Rotation?
   / Trailer Tire Rotation? #1
diesel85
Veteran Member
Vernon, NY
Kubota BX2200
So I got 3 trailers: single, double, and a triple axle. They are all flatbed style haulers. Double and triple are equipment/car haulers.
They are all experiencing normal tire wear. Nothing out of the ordinary. I also keep an eagle eye to the tire pressures. Each trailer has differing amounts of mileage on those tires.
The trailers, when not in use, are stored in a climate controlled area.
In the past, I've rotated them every other year of use. Never seemed to make much of a difference, other than me doing some wrenching and inspecting of hardware and brakes.
Do others think I'm crazy, or should I keep on chugging along and keep to this schedule?
   / Trailer Tire Rotation? #2
The biggest benefit to rotating trailer tires is having the tire off to check everything else out. I have thought about rotating my trailer tires, on my dump trailer, but it’s more because the back axle has several plug/patches in each of them. The rears get beat twice as hard with all the gravel I drive, which supports rotating them.
   / Trailer Tire Rotation? #3
I do it every other year or so, usually the passenger side has more scrub wear (outer shoulder)
   / Trailer Tire Rotation? #4
I keep tabs on tire wear and inflation. I do pull them to repack the bearings every 2 or 3 years so I suppose I could rotate them easily enuf. I do not rotate them because I don't put enough mileage on them for it to be a concern. I replace the tires about the 5 year point. If they were on the road regularly, I'd rotate them.
   / Trailer Tire Rotation? #5
I agree, tandem axles, truck or trailer, will always wear the rears more.
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2025 12V Diesel Pump, Nozzle and Hose with Meter (A50323)
2025 12V Diesel...
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
