Trailer tire milage
   / Trailer tire milage #1
minner
Bronze Member
Arab, AL
Kubota M7040 cab
What kind of milage are y'all getting from your tires? I've got 5k miles on this last set on 10klb tag consistently hauling 6klb. I will be luck to get another 1,000 mi before they need replaced.
   / Trailer tire milage #2
I cant help there, I never put enough miles on a trailer to wear out tires. I did some farming 40 years ago and owned 40 foot cotton hauling trailers. Put about 40 miles per day on them for 4 seasons and they didn't even show any wear. I would think something is likely out of alignment with your axles if you are only getting 6K miles. Maybe you aren't running properly inflated tires also.
I would do a check on the axle alignment to see if they are setting square with the frame.
Whew talking about a pain to tow and hard on a truck believe me I know.
Realistically though those trailers probably only saw the gin probably a dozen times a year?
FWIW most trailer tires are "rated" for 5k-12k miles.
   / Trailer tire milage #4
15,000 miles tops.
More important is age. 6 years max, after that I will not touch them and no tire shop around here will either.
Chris
   / Trailer tire milage #5
On our 15k 5ver I upgraded the tires to g-rated Goodyear g-614. They are 14 ply but with nearly 8k miles, they still look new. If I had to guess I'd say maybe 80-90% remaining. Honestly can't tell any wear yet. They are expensive but worth it in my opinion.
Brett
   / Trailer tire milage #6
Brett
Time is the enemy. 6 years plus they will be a ticking time bomb no matter how much tread is left.
Chris
   / Trailer tire milage #7
Chris
It's only two years old so I figure I've got plenty of time. Zero blowouts or tire probs
Brett
I'm not sure why we are talking about time, it shouldn't be a factor in my case. Mine are 1 year old.
   / Trailer tire milage #9
My 10K equipment trailers actually wear pretty well. One of them had the tires replaced due to age and not tread depth. Prolly had 6/7k on them and still had plenty of tread. I have a 7K enclosed trailer that gets less than 6 k between tire replacements. The axles are further back on the enclosed trailer and I think the scrubbing when I turn causes them to wear faster.
   / Trailer tire milage #10
something sounds clearly bent/out of alignment.
my 10K trailer has several thousand miles on it (regular 300 mile trips to our other property) in the past couple of years and the tires hardly look like they have lost any tread and its a used trailer at that.
Describe the wear? flat spots? (are you frequently locking up the trailer brakes) inside edge, outside edge, chunking?
Pics of the trailer?
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
Entyre Chip Spreader (A51573)
Entyre Chip...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2008  BIG TEX 16' T/A TRASH TRAILER (A52472)
2008 BIG TEX 16'...
2007 PETERBILT 379 SLEEPER (A52472)
2007 PETERBILT 379...
