Trailer support jackstands for (un)loading??
/ Trailer support jackstands for (un)loading?? #21
For occasional use of loading and unloading, I just toss a set of regular adjustable jack-stands under the back corners of the trailer and use removable ramps.
One issue you can run into is that once the tractor is loaded, even if positioned to put the weight towards the front, the trailer springs can squat down enough that there is weight on the back jack supports. A simple pinned jack stand can be problematic to remove. A crank style jack will be easier to disengage when there is weight on it.
- Rick
/ Trailer support jackstands for (un)loading?? #22
I used old Jacks from a truck camper "Cut down" on mine. pictures inclosed. But I have seen some home made just using Square tubing with holes drilled . Thats the way to go fast to use.
/ Trailer support jackstands for (un)loading?? #23
That is a good one, Oldmax. I like that, have to keep my eyes open for some of those things.
